Anyone have this Summit Fuel Cell?? I'm pissed...
Discussion in 'The Garage' started by BozoWise, Dec 18, 2005.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Man this dang poly summit fuel cell sit outside one night in the blazer and the top has drooped in so when I went outside thie morning there was a puddle of water on it covering the top of the fuel fill since it is in the center. Wouldn't doubt the seals leaked and let water in there.
    Anyone have a clue on what I should do besides thrash it and get a aluminum one?? Kinda unhappy over this one since it really hasn't even got to be used yet.
  2. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    summit cells are usually either jaz or rci brands repackaged for summit. they do sell a fast fill 45 degree aluminum neck that has a cap similar to a stock type one. i thought about going with one of those even though i do have an aluminum cell:dunno:
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    every fuel cell ive seen like that.. has caved in on the top creating a bowl... You shoulda just bought the 20 gallon aluminum one...
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    both of mine did the same thing but i havent had a problem with water in the fuel
  5. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    well..(no pun intended)..
    All the fuel cells I've seen are set up like that--so are many stock sending units on gas tanks..remember--if gas isn't leaking OUT of those seals,water cant get IN either..but I agree,it is distressing to see a puddle of water sitting on top of your gas tank..not something I'd want to see either!..
    I think GM designed their stock tanks like that so they can rot out the fuel lines at the sender faster..:mad:
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    My bud Chris has the same fuel cell and it does this also. Of course we don't get much percipitation here in the desert, but ya it does look kind of silly.
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Something I just thought about is maybe the vent on the cap is not open to allow the cell to breathe causing it to shrink in the cold air. Fuel will condense in the cold and expand in the heat (which I am sure you already know). I would imagine in the summer it would do the opposite.
  8. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    youd think so... but it doesnt... i looked in a guys jeep while we were filling at the gas station... going to sandlake in the summer time.. And his cell was all concave on the top... its wierd.. thats one of the reason i didnt go with the plastic one
  9. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Maybe try something like this with some spacers between the straps and the plate.
  10. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    the 16 gallon summit one i got is a big p.o.s. took about three months and it concaved on the top, sender quit working and it leaks out the a.n .fittings. i will be getting a polished aluminum one next.
  11. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    No that is something I just might try. Thanks
  12. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    maybe..
    My friend had the same fuel cell in his 62 Nova's trunk..he didn't like the exposed wires and hose right on top,(feared they would get damaged from putting stuff in the trunk,like lawn chairs he'd take to car shows)..
    So he started looking for something to use as a "cap" to cover it up..he tried a plastic thing they put behind speakers when mounting them in doors,to keep water off them..it worked pretty good,he had to cut a slot in it for the fuel line to poke thru..used 2 of the screws on the ring around the sender to hold it on..:crazy:
  13. 79k20350
    Nov 22, 2004
    7,757
    Ct
    my an fittings also leaked. its an easy fix. you take a 1" wrench and stuf it inside the take, find the back of the fitting with the wrench, now tigheten from the outside that same 1" fitting. suddenly the leak stops:rolleyes:
  14. chevyjeff
    Dec 10, 2003
    118
    WYLIE TEXAS
    i have tightend both of them twice and they still leak. its going in the trash as soon as i get an aluminum one. Might put it on my buddies riding mower or use it for a home made parts washer by cutting off the top
  15. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    Why don't you just get the metal can to go around it? I have yet to see one with the metal can that deforms like you are talking about.
  16. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Do you know where I can get just the can for the outside?
  17. miniwally
    Aug 11, 2003
    3,065
    Colorado
    I think that Summit or RCI sell them just check with them.
  18. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    I have an 30 gal. RCI cell in the back of my P/U but I build a steel box for it that it sits in with a lid on hinges, no water can get in. You may want to think about doing that, it would be cheaper than buying a new cell.
  19. rodney chambers
    rodney chambers Registered Member
    Jun 23, 2005
    50
    northeast oklahoma
    i have the same cell and the same problem. bluggy will not run on water. mine was leaking around the suction fitting. i had to make sure the jam nut was tight to stop the water. i dont believe it has leaked around the fill neck.
