Anyone heard of stretching a FS Blazer and adding a cab?
Discussion in 'The Garage' started by gm guy, Nov 17, 2006.
  1. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    I'm interested in making a 125" wheelbase Blazer with reg cab and flat deck.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Why not just get a burb frame and put a cab on it?
  3. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Why 125, precisely?
    I would think a shortbed (stock wheelbase 117.5") with 56"s in the back and 52"s up front would be right about where you wanna be, and already be set up for the cab/bed. Or you could use a Burb frame (stock WB 129.5") or a longbed (131.5").
    -- A
  4. gm guy
    May 1, 2004
    151
    I want to use a 92 Dakota cab and box because I have one sitting here in the yard with a rolled 74 Blazer that runs and drives great.
  5. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Then I would look for a frame donor from a shortbed truck and use 3 trucks to make one. Isn't a blazer 109" wheel base? I'm not sure you could add 16" of wheel base in any practical manner.
    Running 56s in the rear rotated 180° + zero rate you could gain 5.5"
    Running 52s in the front + zero rate you could gain 3.5"
    Total 9"
    I suppose you could move spring hangers. You'd want to do that in the rear, not much more room in the front after 52s. I'm sure there's another 7" you'd could gain in the rear moving the hangers back further. However you'd run into problems with the front hanger moving into the area where the frame curves up over the rear axle. That might get tricky.
  6. goldwing2000
    goldwing2000 Guest
    That sounds like WAY too much work...
  7. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    It would be a lot of work to stretch one that long, with leaf springs. I would guess you could get to around 116 to 118 with out stretching the frame.
    If you linked the rear suspension, you could make it as long as you want.
    I'm also wondering why you want 125" of wheelbase. I also think that it would be easier to start with a longer frame, either a shortbed or swaping the blazer drivetrain into the dakota (if it already is close to 125)
  8. gm guy
    May 1, 2004
    151
    Thanks for the input guys. I'm just looking to get a 3/4 ton chassis under my dakota and hopefully end up with a GM motor. The reg cab short box is too short but closer to what I want so I'll look into that.
  9. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I know of some people who have shortened frames to work with other bodies but havent heard of lengthening it. I am certain it could be done though as I have seen some crazy stretched limo ideas. As long as the frame was strengthened appropriately at the stretch area then i cant imagine it would be a problem, just lots of work getting the frame square.
  10. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    bob the 'kota bed and just run a 52/56 combo on the blazer chassis.
  11. SierraJim
    SierraJim Registered Member
    Nov 6, 2006
    21
    Eagan, MN
    X2
    install the dakota cab, and then modify/bob the bed to fit. SOunds alot easier than stretching the frame,driveshafts,brake lines,electrical,exhaust, and gas lines.
  12. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    uhh no
    a 2nd gen k5 is 106.5" wb, 1st gen 104''
  13. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    X 3
