Anyone here running a 36" tire with a 6" lift ?????
Discussion in 'The Garage' started by kickinasphalt, May 22, 2004.
  1. kickinasphalt
    kickinasphalt Registered Member
    May 17, 2004
    15
    Anyone here running a 36\" tire with a 6\" lift ?????
    Particularly Super Swamper TSL 36x12.50-15 (which are actually 36.3" tall). Installing a 6" lift in my 71 K-10 and I know 35's are fine but what about these? I'm no rock crawler so I won't be articulating the crap out of the pickup (just general running down crap roads and what not).
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Re: Anyone here running a 36\" tire with a 6\" lift ?????
    No.....Im running 38X12.50 Swampers on a 4" lift on a 70 Jimmy. Does require minor fender trimming. /forums/images/graemlins/thumb.gif
    You should have PLENTY of room with 36X12.50's and 6"'s of lift and not flexing much.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You'll be fine. They might rub a little under full stuff, but not too bad. I run 38's on 7" of lift. I rub when it's stuffed, but no issues on the street, even with the steering wheel at full lock. My next tires will be the 36x13.50 Iroks. They "might" rub because they are a tad wider than my swampers, but I din't think it'll be too bad.
  4. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I was running 36x14.5 on my Suburban with 6" lift and it was fine until I tried to go on rocks and then it would rub.
    mine were wider then what you are going to and you should be fine.
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I'm running 36'x12.50 swampers on 4" lift on my sub and it fits fine, but I hade to do some trimming couse it would have rub pretty good offroad.
  6. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    36 x 14.5 x 16.5 TSLR on a K20 with 4" + 3" and the fenders ate my tires going over the curb at the grocery store
    The problem has now been rectified
  7. bigblazer433
    bigblazer433 Registered Member
    Jul 29, 2002
    38
    El Reno Oklahoma
    I run 36/12.50/15's with a 6in lift on my 87 And I have never rubbed a fender.
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    37" MT/R's on 3" of lift. No tire rub at all.
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    i think the biggest part is the width of the tire.. I have 6" front leafs now.. bushwacker cutout flares and my 40" hawgs fit.. but when you turn (dont have steering hooked up yet... I cant.. I have to cut the fenders to even turn.. I think i will have to hack the bushwackers too...
    my 40" hawgs are on 12' wide rims which pulled the height down a bit to like 38.7" so 38x15's would probably fit better.... /forums/images/graemlins/whistling.gif
  10. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    irubed pretty bad with my 6" and 35x12.50's i think i got a picture somewhere on here i'll have to find it and post it. but it was only when i was realy flexed out.
    You nact realy tell becasue im not turned in that pic but if i was to be turning than it would have hit the fenders. And people tell me i can run the same combo on 4" lift and not touch the fenders /forums/images/graemlins/yikes.gif /forums/images/graemlins/hack.gif
  11. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Would what fits on 73-87/91 still fit the same on a 71?
    My 1979 K20 has 9" of lift (6" suspension, 3" body) with 36x12.5/16.5 TSL SX's and they rub when bouncing through ruts.
  12. RootBreaker
    Nov 29, 2001
    5,117
    173
  13. 87roadwhale
    87roadwhale Registered Member
    Aug 8, 2003
    17
    North-Central Wisconsin
    I also run 35's and 6" lift with no rubbing at all. I did remove the front inner fenderwells, but I never rub on the fenders themselves. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have 6" with 38.5x16 TSLs with some moderate hacking, no rubbage.
  15. FlatBlackBurb
    FlatBlackBurb 1/2 ton status
    Mar 23, 2007
    390
    Santa Cruz, CA
    well im about to put 36x12.5x16.5 interco swampers on my '87 suburban with 4'' of lift tomorrow with very minor fender trimming from the previous owner and we'll see how they do
  16. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    yep yep when school lets out within the next week or two, in goes my 6" tuff country and some 36" humvee bias ply tires. I measure and figured I might need some slight trimming on the rear of the front fenders, pb just the very bottom lip that folds in.
    Remington
  17. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Post up when you're done. Once i finally finish my 9 month long motor swap, i'll be going to the same set up. 6" TC EZ rides and hummers.
  18. uao85
    Jan 2, 2004
    1,867
    Edge of insanity
    I will pb start a build thread at that point, so you will pb see it.
    Remington
  19. jimmy'sjimmy
    jimmy'sjimmy 1/2 ton status
    Dec 22, 2001
    130
    Greenwood Village, CO
    6in Superlift and 36in Dirt Gripz rub when flexing, but made themselves at home.
  20. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    i ran 36/12.5 tsls with out rubbing with a 4" lift
