anyone ID this diff?
Discussion in 'The Garage' started by johnnychimpo, Jul 10, 2006.
  1. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    I got this 1/2ton '90 Sub last month for $500 w/350 700R4/NP241 ,the PO said the rearend was bad. Sure enough the pinion on the 10b had a broken tooth. The driver side rear axle bearing had run down and ate the bearing surface on the shaft.
    What I don't know is the manufacturer of this diff. These pics are with the center pin out, the large rectangular hole is where the pin slides out and one end of the pin is the same shape as this opening. The axles are 30sp and the RPO codes show no factory locker(G80).
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    10 bolt, it's a GM corporate axle. Get a chain and hook it to your boat, it's a boat anchor. Even before it broke.
  3. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    GM Corporate 10 bolt, comes stock on 1/2 tons.
  4. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    I know the front and rear are 10 bolts, I need the actual differential case make. Does it look familiar to anyone. thnx for the quick replys
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Maybe a detroit. Im not real sure. Look closer on the carrier and see, it should hold some clue to who made it.
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    EDIT.....I looked again, I think it is a detroit
  7. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    would like to put it in the front, but it would be difficult to source 30spl shafts when one breaks. The truck has 200,000mi on it but I got it to start while on the jackstands so I haven't driven it yet. I found reciepts in the console where the tranny and transfer case had been rebuilt 40,000 mi ago. Not bad for $500 bucks? located a 14bsf from a '94 3/4t for the rear.
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Car ram rod.... that is all :bow:
  9. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    what kinda diff is that meow???
