Anyone know a good (cheap) source for the red o-rings for the newer hummer 12-bolts?
Discussion in 'The Garage' started by grimjaw, May 2, 2007.
  1. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Ok, I thought I knew the corect O-ring for 12-bolt rims till I found out there is a newer design 12bolt rim. These are the newer ones rated at 3850lbs vs the older 12 bolts being 3500lbs. The quick way to tell the difference is the newer ones have a 13th hole.
    stolen pic:
    Anyone know a good (cheap) source for the red o-rings for the newer hummer 12-bolt rims? These are the two part numbers:
    12342633 Black radial wheel
    12460338 Red radial wheel
    The NSN for the red one is 5331-01-417-1043.
    The problem is these go for $23 each at a HUMMER stealership. Does anyone know the specs so I can order from a non-Hummer source?
    Thanks.
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Have you tried USA6x6? I know they dont have a good rep, just a thought.
  3. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    Well, I bought one online today. Once it comes in I will see if the local parts place can match it.
  4. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    I dont know where to get cheap orings but heres some more pictures.It appears that the 8bolt and 3400lb. 12bolt rims take the same orings but the 3850lb. 12bolt rims use a thinner one.
    If you look at the side by side pic of the 2 12bolt rims you can see the groove width /depth difference.
  5. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    I went to a HUMMER website and they thought I was odd for not wanting to pay $23 to $43 for a REAL Hummer part.
    The cheapest I have found was $12.45 shipped. I am hoping to cut that in half. Really this is not about the money, but I think its silly to pay the 'HUMMER' / Military price for these.
  6. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    How are these holding air? Cheap O-rings: http://coloradok5.com/forums/showthread.php?t=202743
  7. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    They are not. The seal popped at 20 psi. I did not realize when I first posted that there are the two different types of hummer 12-bolts. The ones I listed there work on the older 12-bolts and the 8-bolts. Sorry if someone bought the wrong o-rings.
    As a side note:
    I broke a magnesium H1 hummer runflat.
    I was trying to mount a 37x12.5x16.5 Trxus MT on a 12-bolt hummer rim. I had a bit of trouble getting the wheel to seal and hold air. After putting 20 psi in the tire I heard it leaking badly. So I disassembled the wheel to find the runflat was broken. It appears the was a old hair line crack at one end. As I tightened the rim down the crack ripped like a zipper down one side for about a foot. I guess I am luckly the tire did not get cut by the sharpe edge.
  8. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    Do you have any more details to tell the difference between the two 12bolt wheels. Now I'm not sure which ones I have.
  9. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    Look at MEK5's last picture in post #4. The newer ones have 13 holes in them, but only 12 studs.
  10. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    I've got the newer ones. They have 06-03 stamped into them but no load rating. Think this might be the manufacturing date? Any part #'s for the newer 0-rings? I bought these alreadyhttp://coloradok5.com/forums/showthread.php?t=202743 , not paying $20 something for o-rings.
  11. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Try www.Mcmastercarr.com
    Have to search by the oring specs, not the part #
    I bought my 8 bolt o-rings for like $6 a piece.
  12. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    I bought 10 for $11 but have the wrong ones.I need specs on the new 12bolt "red" o-rings
  13. Big91RustyBucket
    Big91RustyBucket 1/2 ton status
    Mar 10, 2007
    1,429
    New Lenox IL, Area (Chi-town Suburb)
    You must be smoking crack thinking they have a good rep. They have a terrible rep , and he is a terrible buisiness man too.
  14. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    I finally gave up & sold my #3800 lb 12 bolts.
  15. dyeager535
    26,979
    Not sure I'd bank on these numbers, but:
    cross-sectional height 12/64~min/max
    center hole diameter 14 21/50" min, 14 35/64" max
    That's all I could come up with in a search, not sure if it even helps.
    Guess this is a bit of an old post. :)
  16. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    Now you come to the rescue....after I've sold my new never mounted 12b H1's. Seriously thanks for the research, after I sold them I wish I hadn't.
  17. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well i got those same o-rings, hopefully they work. ive got the older 12bolt rims
