Anyone know a lot about wiring?
Discussion in 'The Garage' started by **DONOTDELETE**, Mar 16, 2002.
    Got an interesting one for you. In my truck at night the left turn signal arrow will stay slightly illumniated, and when I click the left turn signal it starts flashing like normal. However the front turn signal, and side marker lights do not illuminate, but the rear does. Once in a while the glowing left arrow will turn dark like normal, and everything will work fine. Sometimes it will work fine for a few days, sometimes minutes, but then it will start glowing again and do the same thing. It used to do the same thing but with the right turn signal, but then that stopped and now it's doing it on the left. You just cant win!!! /forums/images/icons/frown.gif Thanks for your help.
  1. 1BAD88
    1BAD88 Registered Member
    Feb 23, 2002
    89
    bristol ct
    I had the same problem. It turned out to be dirty connectors .At the rear underneath there are snap connects (usually tucked in on the frame .Just find them and spray electrical spray cleaner in them and it should work .Check all fuses .And if you have a tow set up check the trailer power wires for loose grounds..hope this helps good luck.......
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    If the light "will stay slightly illumniated" sometimes...
    It sounds like you've got a bad ground for your lights... maybe out where the bulb plugs into the socket there's a grounding tab?
    It's backfeeding through your turn signal indicator on the dash because it is finding the path of least resistance to ground through that more than likely.
    my 2 cents. /forums/images/icons/smile.gif
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    This may be a longshot, but it worked for BigTex and me. Your wiring harness to the instrument cluster circuit board may be loose. You have to get behind the cluster (remove it) and there is a plug-in right next to where the speedo cable goes in. Make sure that the plug is tight. A Chiltons/Haynes gives a pretty good description of how to get at it.
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Another thing you could try is changing a couple bulbs. While you're changing them, lightly brush out the sockets as best you can. Inspect everything, too, and replace anything that's damaged if you can.
    Good luck! Electricity is a funky thing!
  5. Thanks for your help guys. I am going to get under there pretty soon (not feeling well) and start with the easiest of your suggustions frist and work my way up till I find it. Thanks again
  6. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    try pulling all the light bulbs out on the one side or all on the truck and try only front lights them only back lights until you find the problem socket or ground. Last year I did this and found out there was road salt and ice in my trailer connection after about an hour with all the lights out of the truck. the only thing that had worked before was the head lights. the ice was blowing fuses
