anyone know about 87 yota 2wd brakes ?
Discussion in 'Other Rides' started by R72K5, Jan 5, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    anyone know if 87 2wd yoyo pickup calipers are bolted or clipped to spindles and if bolted then what socket type ? torx ? allen ? hex ?
    also how to remove 2wd rear drums on these little trucks ? slip off or bolt off ?
    thanks for anything
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok figured it out, there are two drilled tapped holes in drum face you hjave to screw in bolt and it tightens up against face of axle flange and it pulls drum away from axle flange, them suckers are on there damn good, it was no fun at all, i rat tail filed and dremel tool grinded the ID of the drum flange hole and the OD of the flange, enough so drum will actually slip on and off for once
    brake adjusters were frozen, stuck at minimum adjustment!
    fixed for now, actually have pedal now finally, feels better than ever has, will need new adjusters kinda soon
    thanks
