anyone know how much a 4" spring/block lift kit weighs?
Discussion in 'The Garage' started by weisel, Apr 29, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    anyone know how much a 4\" spring/block lift kit weighs?
    I would like to estimate shipping charges. Thanks. It is the complete one on ebay from rough country.
    This kit works on 73-87 Chevy 1/2 or 3/4 ton Pickup, 73-91 1/2 or 3/4 Suburban, Fullsize Blazer, and Jimmy. This kit comes with Front luxuary ride double tapered leaf springs, poly bushings for the springs, ubolts, 4 inch block and ubolts for the rear, 4 Heckethorn Hydro 8000 shocks, raised steering arm, brake line relocator brackets, and nuts and bolts.
  2. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    Re: anyone know how much a 4\" spring/block lift kit weighs?
    Well, the front springs, if they are like my 4 inch springs, will weigh almost exactly 90 pounds total. Add a few pounds for the blocks, steering arm, u-bolts, and shocks. I'd guestimate about 115 pounds.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    When I shipped out some 4" blocks and u-bolts they were 30#.
  4. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    So probably around 130lbs.
