Anyone know how much freon is a pound?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Jun 17, 2002.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I got a suburban, they tell me it swallows 4-5 lbs of freon at $80 a pound. I have rear a/c which sucks even worse.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    My friend works at firestone auto center and they charge $97 a pound.
  3. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I just recharged a vehicle which took 1.5 Lbs @ ~$70/lb I think the total charge with labor was around $150.
    FYI
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    It was originally equipped with R-12, but you can change it over to R-134A which is more readily available (you can buy it at most parts stores) and costs much less.
  5. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    You can retrofit it and charge it for about $50.
  6. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    $61.50 a pound at my shop. I may be mistaken but even a sub with rear ac does not take that much unless it had been completley evacuated. If it's not to late, have it retro-
    fitted to r134a. $16.00 bucks an lb.
    Jim
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If the system is just being "topped off", then it shouldn't take nearly that much freon. But if it's being opened to replace a component, then it will take a bunch. I just checked the sticker on my '90 Sub with rear air and it calls for 5.25 lbs to do a full charge. /forums/images/icons/shocked.gif
  8. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    The place i work at needs to raise its prices after reading this we charge $50.00 a pound and 15.95 hook up. Maybe its a TEXAS thing .
  9. TXBIGFISH
    TXBIGFISH 1/2 ton status
    Oct 2, 2001
    297
    Sachse TX
    Look into a product called "Freeze 12" It is supposed to be compatable with R-12 systems and cool better than 134.
    You can do a search and find it, it is about $10 a pound, some locat perts stores carry it too.
  10. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I was just into Advanced Auto and checked on the small 12 oz cans(suicide cans). They were $30 each, don't bother to check unless you have the ASE certificate however. Funny thing is, mine is the first one they issued and it doesn't show up in their books as a valid certificate /forums/images/icons/mad.gif , but we got it straightened out.
