anyone know of a place where I can get a 9 wire connector??
Discussion in 'The Garage' started by 85mudblazin, Jan 3, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I want to but some connectors at the door jamb so it will be easy to take the doors off, I know there are 2 connector for each door up behind the dash but I want to just put 1 9 wire connector in the jamb for ease of install, anyone know where I can get a waterproof 9 wire connector??
    -Chris
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I would try a local boat shop or a marina
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok ill check them out, ill hit the auto parts store and see what they got also
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I got some of the weatherpack style connectors for my dash at the local hot rod shop. They were 4 pin each but the guy said they have them in many different pin configurations. I have also used "dead" wiring harnesses out of engine compartments of various cars/trucks for diffrent things, just clip enough wire behind each side to splice into and your set. Got mine from diffrent projects but you could probibly find some at the local wrecking yards, I'm sure once they're crimped or otherwise damaged they're useless to the yard.
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i'm using a used marine unit we had at work for my dash disconnect setup, believe its 16 pin weatherproof.. they are used to attach engine harness's to the boat harness, for quick engine removal... the one i'm using is off a Crusader, about 3" long x 1" wide.. Mercruiser uses a similar one, but round...
    don't see it listed in my catalog here at home... i'll hunt around the web a little and see what i can dig up for ya... you could probably use a Dinn connector also...
    edit/heres a 9 pin dinn style
    [​IMG]+
    and a 6 weatherpack style
    from http://www.waytekwire.com/
    i would just use a 6 and 4 weatherpack...
  6. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Here are few sources I find useful...
    www.waytekwire.com/ (this is a great source for Weather-Pak and other popular OEM connectors)
    www.newark.com (a good electronic/electrical industrial supplier)
  7. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    MSD has an 8-pin connector PN# 8185 and 12-pin PN# 8186
    I've attached a pic of what they look like.
