Anyone know the difference between HS9500i and the HS9500?
Discussion in 'The Garage' started by Silver84k5, Mar 7, 2003.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Thank you.
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i thought the HS9500I had the integrated solenoids.....
    NITRO
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    HS9500 has a remote soleniod pack and the HS9500i has solenoids integrated into the loop over the spool.
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    ok thx. what does that mean? i got the hs9500. is the "i" better? or is it really no big deal? anything i need to watch out for?
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    With the "i" the selonid pack is mounted over the drum, the other will be required to be mounted elsewhere. I don't know how else to explain it other than go to your local 4WD store and look at them.
  6. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    I just installed my HS9500I a couple weeks ago. I will try and post a pic latter today(havent taken any yet).
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    isent it RS not HS?
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    No its HS=high speed, almost as fast as an 8274
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    HS9500
    HS9500i
    theres the pics, now someone more intelligent than i can explain the diff.
  10. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    The pic didnt work for the HS9500, but when i looked at the bottom i noticed the HS9500 doesnt have the bridge over the Cable, Mine has that bridge, like the pictures of the HS9500i, but on my winch it doesnt say "i" on there, hmmmmm
    There now i got the pic to work, Mine looks exacatally like the "i" hmm, but it only says HS9500 on it, wierd.
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If you have the "bridge" w/ the selonids mounted in it then its the "i". Both winches are the same so they may share a common label.
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I like the hs9500 more than the "I" version. Without the solenoid pack on the winch you can put it somewhere where it will stay dry (which will help it last longer) and it will block less air from getting to your radiator...it is also cheeper.
