Anyone know the fuel pressure a TBI pump makes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84_Chevy_K10, Jun 29, 2001.
  1. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My friend is putting a carburated engine in his TBI truck. I know TBI is fairly low pressure, but low enough for a carb? I think it's 10-13, which is too much, but a pressure regulator could bring that down to the 4-7 range.
    At any rate, what kind of pressure does a TBI pump make?
    Tim
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I believe you are correct, 10-15 psi from a TBI pump.
    Ratch
    <A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A>
    **K5 - What more is there to life?**
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the reg is what sets the pressure that the pump maintains.
  4. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Make sure you use a regulator that has a port to cycle excess fuel pressure back to the tank, otherwise you'll burn your fuel pump up in no time. Look for a 3 port fuel regulator, incoming, carb & return. I run one and set carb pressure at 5-6psi for a Holley. It's also an excellent way to keep from experiencing vapor lock.
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 stroker. Build it Bulletproof and take it fishing!
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Cool. Any suggestions as to what kind of regulator to choose, where to get it, and how much?
    This kid was going to buy two sending units and run a mechanical pump! Good thing I told him that wasn't necessary, what a waste of work.
    Tim
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I ran a regulator from Summit in this kind of application with no problems at all.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
