Anyone know the size of the...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85blazerk5, Jan 26, 2005.
  1. 85blazerk5
    85blazerk5 Registered Member
    May 30, 2004
    75
    WV
    fill plug on the my differentials. What size socket do I need to remove them? I have a 85 K5 with 10 bolts. Thanks in advance for any help.
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I believe they should have a female square drive hole that a 3/8" ratchet will fit into.
  3. 85blazerk5
    May 30, 2004
    75
    WV
    Mine is square, but it isn't a hole...
    Mine is square, but it isn't a hole...I can't find anything to fit it, I am new to all of this.
  4. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    An adjustable wrench should do the trick ;)
    Thomas.
  5. 85blazerk5
    May 30, 2004
    75
    WV
    Yeah
    I guess you're right, just stuck in there pretty good and the adjustable keeps slipping off.
  6. Grim-Reaper
    7,385
    Atlanta
    on the pipe style I have found that you can take them off with a 12 point socket. If its rounded form using a crecent you might not get it to work. Specialty tool place or plumbing suply place will proably be able to get you the Square drive if you need it.
  7. 85blazerk5
    May 30, 2004
    75
    WV
    is there a certain size 12 point socket?
  8. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    3/4" 12 point comes to mind, but its been a while
  9. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I have an 8 point socket I use, go pick one up, should come in handy
  10. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    I use a 5/8 open end wrench.
    Later
  11. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    vice grips!;)
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Pipe wrench will always work :D
  13. 85blazerk5
    May 30, 2004
    75
    WV
    Just went ahead and used vice grips. Thanks.
