Anyone know why the serpentine water pumps don't have grooved pulleys?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Oct 7, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Anyone know why the serpentine water pumps don\'t have grooved pulleys?
    They don't have any of the grooves on the pulleys of the new water pumps and I was just wondering why?
  2. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Re: Anyone know why the serpentine water pumps don\'t have grooved pulleys?
    The backside of the belt rides on the pulley if it's smooth.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    yeah, they are reverse rotaion pumps, so they turn the other way, and like he said, other side of belt turns them
  4. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Cool. Thanks never knew that before. How bout this, what are the 2 hoses coming from the water pump? I'd guess them to be 1/2" hoses, and what's the easiest way to get them off? Thanks again
  5. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    Not to be too much of a smart ass, but I would say to pull them off. A small screwdriver stuck in the end to lever them off may help also.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I am assuming you took of the clamp, I use a plier and grab the outside with slight pressure and try and twist it loose then it comes of easy.
    One time it wouldn't rotate so I pinched part of the hose and it broke loose and then the rest just broke loose when I twisted it.
    If you didn't understand my explanation, PM me and I will put it in another way.
    IceMan
  7. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Lol, sorry shoulda been more specific. I took the hoses off, but the things under the hoses, I don't know what the heck to call them. The things the hoses clamped over, are they threaded or what? I'm guessing it was a line to something and and a return line back to it. I just don't know if I can actually get those off, of if I'll have to figure out how to plug them.
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    They should have a hex fitting on the bottom (near the pump) that you can get a wrench/socket on and they are threaded in (at least on most) and I believe they are NPT threads, so you can go down to your local hardware/plumbing supply store and get Pipe Plugs and some tephlon tape to put in there.
    Why are you removing them (Heavy duty cooling)?
  9. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Sound like he might be changing out the pump and needs those fittings.
  10. jmd
    jmd Registered Member
    Oct 25, 2001
    63
    Phoenix, Aridzona
    Napa should have the fittings no problem, or a plug to replace them if you're re-routing heater hoses. Just take the olde one in with you.
    Matthew
  11. Leadfoot
    Nov 28, 2000
    3,112
    Light bulb goes on and Chris finally wakes up /forums/images/graemlins/deal.gif /forums/images/graemlins/rolleyes.gif
    Thanks! /forums/images/graemlins/thumb.gif
