anyone make a fixed shaft for a model 208 transfer case
Discussion in 'The Garage' started by camiswelding, Mar 21, 2004.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I see them for everything but the 208/// anyone make one.. whats the trick setup for the rear of this case
    Im going to use A HAD shaft with an ebrake on it
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no. The trick is to get a 241 like I did. There is one kit but its crap, its a flange that slides over the existing shaft like your factory slip yoke does and then you drill a hole into the output shaft and bolt it on. Aka it weakens the shaft and adds no bearing support like a 241 SYE kit does. You can pirate parts from a Dodge NP208 and convert to SYE but that is the only way.
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Use parts from a dodge 208 to make a fixed yoke.
  4. Nike
    Nike Registered Member
    93
    Jefferson City, Missouri
    Do you know if the fixed yoke on the Bronco 208's will bolt on the chev 208? Thanks Nike
  5. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    What year dodge 208?
  6. ryanvz1
    ryanvz1 Registered Member
    Jan 20, 2004
    34
    I don't think it will line up, but maybe.
  7. outlaw612
    Feb 11, 2001
    2,342
    Im not positive of the year range, but I believe mine was from a mid 80's.
  8. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    thanks for the replies... Ill take a look at the dodge and see if it will work
    cam
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I was looking through a book today at work, and it appears the only year for the NP 208 in Dodge trucks was 1980. Could be incorrect though.
