anyone make homemade body lift ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Feb 8, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    some kind of steel pipe for the bolt sleeves, and pieces of steel for spacers, or ?
  2. noJeepshere
    noJeepshere I Drive Trains! Premium Member
    Jan 2, 2003
    8,585
    754
    City of Sand, UT
    dont make one, itll be better to buy a suspension lift at any rate. i believe it is superlift that is offering a 2" lift for $99. body lifts only work to, in my eye, clear a bigger engine. you would also have to extend the transmission and t-case shifters to compensate, also the brakelines and several other things. even cheaper would be to make blocks out of 6ga. steel to use as poormans lift blocks on the axle, if you build it yourself. 3" is as high as i would go this way. but the best deal is to buy a lift from a company. they take alot of the work out of lifting.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I know a race team that built their own. They used solid chrome moly tubing, drilled out the holes for the bolts. They only went with 1" lift.
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I had one made YEARS ago. The guy used solid round stock and drilled out the center for the bolts. That was almost 15 yrs ago and the BL is still intact last time I seen my old Cherokee.
    I really wouldnt recommend it tho. I only had mine made because I couldnt find a BL for a F/S Cherokee, and I didnt realize that you can buy just the blocks from some shops.
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Body lifts are really not an area where you want to go cheap and do it yourself. Just bite the bullet and buy a kit. This way you will have the right parts. There is more to it than just putting in some spacers. Just think of all the stuff that goes from the body to the frame like lincage and stuff.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have to disagree with most, I bought my kit for the Jeep Wagoneer and it came missing 4 blocks and I had to buy them seperate.
    And all I got was 10 plastic blocks and 10 grade 8 bolts that were smaller than what I had.
    I had to get bigger bolts that still fit.
    Now I am working on a K5 body lift and I am using aluminum solid 3 inch diameter and I am drilling them for the bolt.
    up to 2" long it will cost you less than a kit and you will have aluminum which is stronger and will not melt.
    3" and you brake even.
    Just don't use Hokey pucks or tube and you should be fine, use aluminum or steel solid and drill them.
    /forums/images/graemlins/thumb.gif
  7. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    I agree w/ you. Nothing special about a spacer. You can also buy the plastic that most body lifts are made of in stick form and cut it yourself.
  8. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Get ahold of Muddytazz I do believe they are making some for his dads Burb out of aluminum.
