Anyone make their own shackles?
Discussion in 'The Garage' started by howdiy, Mar 26, 2007.
  1. howdiy
    howdiy 1/2 ton status
    Jan 28, 2004
    3,309
    Fl
    They seem pretty easy to make. Just some 1/4inch steel from lowes and a drill press to make them.
    Also do you guys just get your springs from like discount auto? I'm doing a 52" front swap with 88-98 springs in the rear.
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I made my own. bought a 4' stick of 3/8x2" steel bar stock, cut on the chop saw, tack welded all 4 together (at the corners). Drilled the holes on a drill press. I then used a bolt through each of the holes, with a 2" OD washer on each side of each end. Tightened the nut/bolt down, and used a grinder to round the ends, using the big washer as a guide. Because I tacked near the corners, rounding the ends cut off the welds. Worked great, took a couple hours total time (if that). Hung 'em, primed, painted. .. I also did 56" springs up front, Got mine for one of the parts trucks in the yard. Same with my rear springs.
    Paint drying
    Installed
  3. howdiy
    Jan 28, 2004
    3,309
    Fl
  4. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    My 56" springs came from my other truck, and the 52"s came from the rear into the front. I'm cheap ;)
    Yeah, front shackles are easy. I welded 1/4" spacers into the 3/8" strap -- 1/4" seems a bit thin -- but you could do washers if you don't wanna weld. Kert makes some for this very purpose.
    http://www.slosh.com/ck5/new-front-shackles-painted-1.JPG
    http://www.slosh.com/ck5/new-front-shackles-painted-2.JPG
    At some point I'm gonna weld a piece of tube across them, towards the bottom, like this pic I stole from somebody here:
    http://www.slosh.com/ck5/crossed shackles.jpg
    -- A
  5. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    X's 3 on the 3/8". The 1/4" shackles you see avertised are for those pesky little heeps. -Eric
  6. Snowman1000
    Snowman1000 1/2 ton status
    Jan 28, 2007
    518
    Freeland Michigan
    You can make those they dont have to be hardened or anything someone I was talking was replacing his and said that they had to be hardened seems straitforward might have to make myself a pair.
  7. howdiy
    Jan 28, 2004
    3,309
    Fl
    Not cheap. What sucks is I don't have any springs that arent in use :( So I'll have to buy them. Should I tryand get GM ones? I know on cars alot of the aftermarket leaf springs are way stiffer than stock.
    I didn't realise that I needed to weld spacers. Good thing I asked here. I'll probally weld that bar connecting them also.
    1/4 inch was just an estimate. I'll make sure to get 3/8
  8. dremu
    Feb 27, 2000
    15,967
    459
    Well, could do junkyard, or yeah, aftermarket's prolly okay. Donno 'bout stiffness; I ended up removing leaves from my 56's (donor was a 1-ton with 8- or 9-leaf packs) and adding one to the front 52's. :donno:
    Don't HAVE to weld the spacer, just slicker than putting a spacer on, or god forbid, stacking washers. The crossbar is added insurance.
    -- A
  9. howdiy
    Jan 28, 2004
    3,309
    Fl
    I'll probally just take the springs also then when I get my 14BFF
  10. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
