Anyone mount and balance their own wheels/tires?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boss, Oct 22, 2001.
  1. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I'm thinking of starting to do this, since I'll be getting either beadlock wheels or the tirelock system for 16.5" wheels. Don't know of any shops around here that will know how to mount beadlocks or the tirelock, so I'll have to learn to do it myself.
    Yall think this will be a good tool for balancing?
    http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=41210
    Hope someone here has experience with it before.
    And this for the tire mounter/changer:?
    http://coloradok5.com/gallery/BeforeNAfter
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I'm no expert on tire balancing...but wouldn't the balancer just give you static balance only? I guess that would be better than no balance...
    The tire changer looks a lot like manual labor to me...[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    My dad sells the actual balancer/changers the tire shops use... I could hook ya up [​IMG].
    I've heard those tire changers are dangerous. Not sure if it's that exact kind, but I've been warned about them.
    89 K5 Silverado
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Come to think of it, he has a used one sitting in his warehouse right now.
    89 K5 Silverado
  5. Boss
    2,550
    Maryland
    Oh yeah, I'll be trying this out with 39.5"x15x16.5" too! [​IMG] That might be a bit much for these tools.
    TRusty, LOL, seems like everything I do is "manual" labor though [​IMG]
    I'll PM you Mud.
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    LOL...I think 39.5's would be a little tough to mount using that changer.
    I'd look for a truck shop, they usually have the equipment to deal with larger tires.
    Rene
  7. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Try this link<a target="_blank" href=http://www.centramatic.com/>http://www.centramatic.com/</a> for balancing, that way you mount the tire and put it on the truck and you're done.
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  8. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Any tire shop should be able to break the inside bead for you, thats the only thing you need a tire machine for with beadlocks. If at home, there's always the 2x8 trick. As for balancing, good luck. You can only put pound on weights on the inside, and be carefull with caliper interference with tape-ons (if desperate, you could always put them on the outside). I tried Equal (balance powder) with poor results, and Centrimatics are high dollar and they still wouldn't promise me it would fix the problem. The biggest issue with the balance is how well you can get the outer bead centered on the wheel/bead lock.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  9. Boss
    2,550
    Maryland
    Yeah, I heard about the equal and heard they aren't worth a damn. How much the centramatics run? That sounds interesting.
    These are mainly going to be wheelin' tires only. I'm getting a set of street shoes for normal driving. But I like to have them atleast semi balanced b/c I know I'll be driving them on the street some. I was thinking about the tape ons, and putting them inside the outer rim.
    Hey, Pete, would you mind elaborating a little more on your 2x8" trick?
  10. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I use the manual tire machine all the time with no problems. The biggest thing you want to do is buy a slide hammer bead breaker and practice a couple of times on an old tire and wheel. I also use the bubble balancer, mine is a sears craftsman. They work great as long as you don't plan on going over 75 or 80 MPH. Something elso to remember is that aluminum is very soft and only bends one time without breaking, keep that in mind when you are pulling the bead over the wheel rim. If your balance is way off let the air out of the tire and rotate the tire on the wheel before adding weights, this works well most of the time. If you get the stuff from harbor freight you will need to reinforce the beadbreaker on the machine as it will bend with thick or cold rubber. also don't forget to get a valve stem puller/installer and also a valve core puller/installer.
    If you have any questions on how to use it feel free to let me know.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=) [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/chevyracing>http://community.webshots.com/user/chevyracing</a>
  11. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    ..... there's a machine to mount tires? I used to just grab 2 tire irons, a bottle of soap, and slip them on. 16.5's are a piece of cake to get on the rims... the real trick is getting the tire bead to make enough contact with the rim to inflate it. on smaller tires (9.50x16.5's) on stock rims, its no problem at all... mounting my 33x12.50's on some 9.75x16.5 rims was a task that I finaly gave up on, and just took them to a gas station, and gave them 5 bucks a tire to inflate, and balance them. thats the easiest way to mount &amp; balance your own tires... for bead locks, I suppose you could mount them yourself, then take them to a station to balance them, but &lt;shrug&gt; do you really even need to balance them since they're probably going to be used mostly for offroad, with almost no highway use at all?
    -Rich
    My truck isn't ugly, you have a skewed sense of beauty
    <font color=blue>2007 Ford XLS++ intrepid Ram Superduty 7000 R-type's suck</font color=blue>
  12. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    I priced out the Centrimatics a few years ago, can't remeber for sure but I think they were at least $400. I gave up on balancing mine, my brother did a couple of them when he worked a Discount Tire, helped a bit. I can't do tape-ons on the inside since I run 15" wheels. If you try to balace them, make sure they are warm when you do it, or at least that they have been driven on lately. They flat spot really bad.
    As for the 2x8: Lay the tire/rim flat on the groud, with valve stem removed. Lay the 2x8 on the tire, with the end of the board at the edge of the rim. Drive truck on board. Rotate and repeat tire/rim if neccesary. Of course this isn't particularly good for the tire. I think this can also be done w/out the board, there are a lot of variables involved. You'll have to use your best misjudgement.
    Pete
  13. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    Boss I mount mine, but my machine is maxed out at a 36 on a 10" wide rim. I also have a bubble balancer. It works ok for the truck but I get the ones for the car done at the tire store. You don't need a tire machine if you get the bead locks. The outside bead is the one that is hard to break and that is what gets cut off and replaced with the new parts. Now that I think about it if all I needed to do was break the inside bead I could do as big a tire as I could pick up, as long as the rim was smaller than a 17" diameter.
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
  14. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Some buds and me mounted some 33x12.50"s one time. They were old and we were having a hell of a time getting them to stop leaking around the bead. We slobbed on some PVC cement and it worked. The guy ran them on his truck for a couple months with no problems.
    I am about to try putting shotgun pellets in my Swampers to balance them. I am too lazy to get out there and do it, but as soon as I do, I will post an update.
    Still Poundin' "pavment" after all these years!!! [​IMG]
  15. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Boss-if you go with the TireLoc system-you'll want to mount them yourself and 16.5 tires are easy. I can place one of my wheels on the floor and throw the inside of my tires over the lip without even using anything. I take my tires to a semi tire place and they line up huge tractor weights on the inside to balance then I cut the metal clip off and tack weld the weights to the inside of the wheel so they can't come off
