anyone open up a front diff. ??
Discussion in '1983-2005 S-Series models' started by chevydude, Mar 8, 2003.
  1. chevydude
    chevydude Registered Member
    Dec 10, 2000
    38
    mat-su valley alaska
    my wifes 92 s-10 needs a inner axle bearing,has anyone out there split one of thoe diff's or is there some way of replacing the axle bearings without dropping the whole thing and dissassembling it?
  2. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    it acan be done on the truck you will need to pull the rear drum on the side that needs changed the open the cover and remove the c clip and slide the axle out then it can be changed hope this helps
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    I haven't had a small front differential apart but I repaired the front differential on my '95 half ton, I think they are similar in design. Which side axle bearing needs replaced? I think the axle stub shaft can be removed and the seal and bearing are pressed in the end of the axle housing, they can be pulled out and replaced without removing the differential. You may have to completely remove the axle shaft to gain access to the inner axle stub shaft though.
