Anyone "pulled" their rear fenders?
Discussion in 'The Garage' started by pismorat, Mar 8, 2005.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I have seen it on pre-runners mostly, where they use the stock sheetmetal bedsides and pull it out for tire clearance. I want to try this to keep some weight in the rear of my pickup and not let my tires rub (I like the "uncut" look for now). Anyone doen it and have pics or a write-up? Thanks. :truck:
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I've just seen write-ups done to Rangers.
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I've never seen this done to a fullsize chevy. The closest I've seen are fiberglass bedsides that are flared like you're talking about but they're made for pickup bedsides. It'd be a pain to do to a K5 because you'd have to bondo or glass the new pieces into the sheetmetal. IMHO it's not worth it, bust out the sawzall :hack:
    Edit: Just realized it was a pickup, statement still stands though, you'd almost have to do a fiberglass setup and that would get wrecked the first time out. Glass doesn't bend, it cracks.
  4. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    is this what you mean..
  5. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    I guess I read it wrong:grin:
    that is not exactly the uncut look.......
    anyways, the fibergl;ass optiion is not that bad, further more if you do your reasearch on it it is not your standard plastic, the stuff is durable depending on what you go with.
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    OK so I exaggerate a little bit about the first time out part, but glass does break instead of bend. It depends on how much damage you plan on doing to the body. I can speak from experience on Glassworks Unlimited fenders. We put a set on my friend's S-10 and yes they are fairly sturdy but trees are heavier duty and I'd rather bend crappy sheetmetal than break expensive fiberglass. Maybe we're way off track here and you're talking strictly about metal work. Oh well, I'll shut up now and go to bed.
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Yep, my stepdad did it to his '89 fullsized Chevy. A little different though, it's a street truck and he did it so he could clear 315/60r15 tires on all 4 corners. The front fenders are done too, but those had to be cut and have extra material welded in. The bedsides where hooked to a portapower all around the fender opening IIRC and just stretched out a couple inches. It looks pretty cool and clears the tires really well. Unfortunately the only pics I have you can't tell that anything is stretched.
  8. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Yah a port a power is really nice to do it with. I helped a freind do this to an s-10 and we tack welded a jack onto the inner fender and used a block of wood on the other end. It worked pretty good.
