Anyone put a 292 in something where it wasn't originally??
Discussion in 'The Garage' started by sled_dog, Apr 6, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Anyone put a 292 in something where it wasn\'t originally??
    I have a friend that got a K5, hated it beat it, now its grown on him. He is a 327 nut and talked about puting a blown 327 in it. Well now he shifted again. He is in the process of puting in a 292 I6 with an SM465 and NP205 behind it. I'll get pictures next time I stop around. Can't say I see the reasoning but to each his own. He did say if he ever puts a V8 in it again it has to be a big block.
  2. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Re: Anyone put a 292 in something where it wasn\'t originally??
    I've got a 250 in my 1966 boat. Runs like a top and has all kinds of torque. Not sure of the specs, I like the old chevy inline 6, but no way would I put one where a SBC was. If it's there, run whatcha brung, otherwise, don't expect a 292 to hold a candle to a SBC, or BBC for that matter. IMHO.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I had one in my beater 69 Chevelle 300 deluxe when I was 17.Someone swapped it in when the old motor died, It was a real bad body , but the 292 would light em up real good when I dumped the clutch. /forums/images/graemlins/thumb.gif
  4. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    We also have a 250 in our boat, its a late 80's tri-hull though, originally had a 4 cylinder, the 250 is rated at 165hp with points ignition and 2-bbl carb, I expect a HEI and 4-bbl will bump that up some. This motor actually came out of a mid 80s single hull boat which we bought for 600 bucks for the engine which was in very good shape and fired right up at the dealership. Interior on boat was crap but engine looks like new.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Make sure if you do put electronic ignition and a 4bbl carb on your boat that you use a MARINE distributor and carb.
    I used to work on boats and I can't even count how many asshats I've caught trying to put a car carb, starter, alternator, or distributor on a boat. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i know of a 76 or 77 nova coupe that an old guy put a 292 into, had to weld extension plate on pass side to make it work and had no rom for a fan
    250 doesnt have the instalation issues that the 292 has, the 292 is pretty unique, is taller overall,
    seems to be longer overall too, and is a truck engine only and therefore is a torque producing engine rather than a hp producing engine
    good luck
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah the motor mounts are proving to be a good issue. Hes kicking himself for not just going and finding a 292 4x4 and getting the mounts. Its interesting, weird to look under the hood and see this big wall splitting the engine bay right in half.
  8. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I have just that combo - look at my signature for spec's .
    What Ya need to know ?
    I went from a healthy BBC to a 292 - something must be wrong with me /forums/images/graemlins/eek.gif ! 292's are way cool but they are not for everyone .......
    When I decided that I wanted to do a in-line project I found a few donor engines :
    Motor # 1 is out of a 1972 C-40 Dump Truck
    Motor # 2 is out of a 1968 C-10 Cab Chassis ( special order truck )
    Motor # 3 is from a 1978 C-20
    Motor # 4 is out of a 1978 K-30 Wrecker
    Motor # 5 is out of a 1979 K-30 Crew Cab
    Motor # 6 I got at a swap meet and is a 1963 model engine with a steel crank.
    I wanted to get a few motors to gain some spare parts and have a few options of pulleys / brackets / motor mounts and stuff - after all GM ain't making these motors any more. I figured I needed to get a few so I would not be in a bind if I ever needed some parts.
    Tom
  9. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Paging TARussell... Paging Mr. TARussell...
    EDIT : Man I type slow. /forums/images/graemlins/doah.gif
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Cool, I will be very interested to see it in action. His K5 has 14 bolt out back, D44 up front, and 35 All Terrains all around. He claims it will be fired up on friday, I don't know, I will be there just in case.
  11. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    If he is after low-end torque than he should be real happy with the power band of the 292. I went with T.B.I. and an aftermarket camshaft along with higher compression pistons - all in an effort to gain more power at idle.
    I am hoping that with my motor choice, gearing and a Doubler I will be able to look like I know what I am doing in the rocks when we start to travel to other places to go wheeling .......
    I got tired of beating my trucks with lots of horsepower and big engines in the mud/swamps - now I want to go wheeling in the mountains and light rocks , so I hope the 292 will be just the ticket .
    Tom
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    thats his goal so we shall see.
