Anyone Put A Olds 455 In A Blazer?
Discussion in 'The Garage' started by HEAVY METAL, Jun 1, 2006.
  1. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    just picked up an '69 olds f block 455 rocket... was wonderin if any of you ahve doen the same? any tips, tricks? any input would be greatly appreciated yo! :D
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It should bolt in maybe need pontiac to chevy mounts I can't remember if my bro had to use special mounts when he put a Pontiac 400 in his camaro but it fit in that. I would think it would bolt in like a 454 would.
    I know that wasnt much help put it def sounds doable. What kinda numbers are you looking at with that thing.
    Ira
  3. HEAVY METAL
    Jan 10, 2005
    386
    stock is 400 hp and 510 ft/lbs.... i want to bore it out to 468 c.i. and go form there?
  4. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    my friends got a 455 in his 86 C-10. it fits but is very close to the frame rails. too close to run off the shelf headers.
  5. NJBLZ
    NJBLZ 1/2 ton status
    Jan 4, 2005
    128
    New Jersey
    Something else to consider...
    The buick/olds/pontiac/cadillac bellhousing pattern is different from the chevy pattern. Those engines will not match up to a chevy transmission. I've seen a 455 olds in a 2wd pickup, but the transmission was also the olds bolt pattern type. Before chevy started using the 6.2 diesel they used an olds 5.7 diesel, in 1979-1980 or so. I think the guy used those factory 5.7 olds motor mounts on the 455. The olds deisel equiped trucks also had the b/o/p/c transmissions, I guess they were turbo 400s. I dont know if they made any with the 4x4 tailshaft.
  6. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    The 5.7 diesel mounts are the way to get a "bolt in" deal. Not sure what to do about exhaust. Olds and Pontiac are different. You can get an adapter for BOP to Chevy bellhousing pattern for about $50 last time I checked.
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The biggest obstacle has to be the exhaust. The olds motor points the exhaust ports straight at the frame, and the motor is extra wide, leaving little room. Using stock manifolds might give you enough room.
