Anyone put a sub tank in a pickup?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by morphed86k10, Feb 10, 2003.
  1. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    Just like the subject line reads, I'd like to know if anyone has put a suburban tank in a pickup. I'd like to ditch the 16 gallon saddle tanks and go to one 42 gallon sub tank where its less likely to get hit by rocks.
  2. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Installed one in a shortbed truck a couple of years ago. We reused the crossmembers from the sub to make it work. the down side in a shortbed is that the front of the tank protrudes over the rear diff. Not a problem for the truck it went into but it could present a problem with one that had a lot of flex and a short suspension lift. In a long bed truck there would be no clearance issues.
  3. morphed86k10
    Jun 25, 2001
    463
    Reno Nevada
    Thats pretty much what I wanted hear, since it'll be going into my longbed.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I am doing something similar, using a long bed frame relocating some stuff, and putting my blazer tank and body on it.
    I am probably working on a 118-120" wheelbase.
  5. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    Is the crossmember just a fuel tank support or does it replace a x-member on the long beds? Not real important, but does anyone know if the x-member can bolt right into a long bed?
    andy
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    It doesn't replace anything but it helps in the rigidity of the frame.
    The GM frame twists a lot and the more you can do to help stiffen it the better.
    I am trying to find a location for an X member to make it even stiffer, somewhere in the middle.
    You have to drill the holes for the tank cross member but it will fit perfectly otherwise.
  7. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    what did you do for a filler tube?
  8. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    We (ducttape and I) have been scheming to do something similar to his /forums/images/graemlins/truck.gif. Our plans however were to put the tank at the front of the bed with a hole cut through with half of the tank above and the rest below. The bottom half will be slightly higher than the bottom of the frame and will have plenty of room to clear the driveshaft. This will be a 40 (?) gallon tank out of a diesel /forums/images/graemlins/burb.gif.
