Anyone rebuild their own auto trannies?
Discussion in 'The Garage' started by big pappa b, Dec 24, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Just wondering what tools are involved in doing a TH350 or 400?
    thanks
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I did my th350 with only special tool beeing C-clamps, and agood set of those dentist tools to pick out one of the snap rings. Oh yeah and GET A BOOK Mine was a haynes tranie repair manual. It tells step by step how to do it and its even got pictures /forums/images/graemlins/eek.gif
  3. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Pump puller, autozone probably has a loaner.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    RyanB has done his own tranny's
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I did my own and only needed picks to get the snap rings out. Pump puller would be nice but not necessary. There are two holes in the pump that are threaded and you can stick some long bolts in those two holes with something on them like a slide hammer and the pump comes right out. Just have a really clean place to do it.
  6. dyeager535
    26,978
    Yep. You can unbolt it, turn the bellhousing towards the ground, and drop it on something, like your lawn. The pump will just dump out.
    I did a TH400 and Th350, only thing I would have liked to have had was the 1st/reverse clutch tool. Could have made one I guess, but for one or two times, I just took it to an auto trans shop and paid a technician $5 to do it for me.
    Guess I could have done the spring compressing with C clamps, but instead I used a shop press. Actually worked good, although had to get creative on how to mount stuff. /forums/images/graemlins/smile.gif
    I thought the 400 was easier than the 350, then again the 400 is what I "learned on". Amazingly enough, I saw one of the transmission rebuild videos (for a 200-4R) and after using the manuals for the other ones, the video was the hands down winner.
  7. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Thanks /forums/images/graemlins/thumb.gif I thought as much. I remember a few years ago a friend of mine rebuilding them and I seem to remember him fighting a lot with some of those snap rings
  8. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Yeah, I bet a Vid would be better than a book, but hey if all else fails get both! /forums/images/graemlins/pimp1.gif
  9. Grim-Reaper
    7,385
    Atlanta
    Yeah I did a TH350. So far so good. Still running fine 4.5 years later.
    I took a Harmonic ballancer puller, peice of 2 inch wide flat stock, 3 3/8 x 1.5 inche bolts with nuts and made it function as a compressor for the clutches. It even did the #1.
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i do all of my own plus some customers /forums/images/graemlins/thumb.gif
