anyone replaced a pass window on a ford ZX2?
Discussion in 'Other Rides' started by LKJR, May 9, 2003.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    girlfriends car got broke into last night, smashed out the pass side door window. anyone ever replaced one of these? I found one here in town for $125 and it's a whole lot cheaper than the deductable. just wondering how difficult this is knowing ford has a lot of goody tools they use on some things.
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I used to work gor a Ford dealership in the body shop. IIRC they are pretty esay to do, pull the door panel and outer weatherstrip. The weatherstrip might have bolt in one end so check before you start pulling.You will also need to take the bolt out of the bottom of the window runs. There should be some access hole in the door to reach the bolts that hold the window to the regulator, take the nuts off, pop the bar loose.Get a shop vac and suck the old glass out of the door, make sure to clean the glass out of the window runs or you will be doing this again. The installation is kind of tricky getting the window back in, you might have to try a couple of different angles to get it in. Slide it in the door, all the way to the bottom, slide it bac in the runs and slide it up tilll you can bolt it back to the regulator. Bolt it up, put the bolts back in the runs and put your weatherstrip back on and door panel. PM me if you have any ?'s
    Krennen
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    already got it done thanx
