Anyone run 35's With NO Lift!?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nitrodrip350, May 12, 2002.
  1. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
    Anyone run 35\'s With NO Lift!?
    I have a set of BFG's that are 35's and need to know if anyone has trimmed (hacked!) the fenders to make them fit? I have the tires, axles, and conversion 8 lug front. Will just need the 8 lug 15x10 rims and a way to put them on. I will be buying the lift later and have rusted out fenders so don't care how much since I'll be replacing them later.
    Thanks, Shane
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: Anyone run 35\'s With NO Lift!?
    i have seen it done /forums/images/icons/smile.gif need lots of trimming lol /forums/images/icons/smile.gif
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Get the swaz-all out.. cause you will be trimmin like a mofo!
  4. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    Ran some 35" D/T on 15x8 rims for a day.....turned them "gingerly" since I hadn't trimmed the fenders on my stock '75 ! /forums/images/icons/wink.gif
    Doc
  5. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I ran wore out 36x12.50 TSL/SX's on my '79 k10 with no lift. I had them on 7" wide factory suburban bullethole wheels. The fenders were cut in the front and beaten back at the rear. The rear tires rubbed the wheelwells when it flexed good. To use 15" wheels with your 8lug, you need lots of offset (2-3" backspacing). The offset of your wheels will affect fitment.
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>No you dont. I run an 8 lug 44 with 15x10 wheels with 4 1/8" backspace.
  7. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    It is a suggestion to use 2 1/2" backspacing. If you had a D60 it would be a necessity.
  8. Nitrodrip350
    Jul 22, 2001
    358
    Centennial, CO
    OKAY!! Second question! Can you remove the rear tubs or inner fenders? I know that I can do this with the fronts to allow more metal to be removed but the rear has the inners too right?
    Thanks, Shane
  9. Nitrodrip350
    Jul 22, 2001
    358
    Centennial, CO
    Come on someone has to have done this before!!!
    TTT - Shane
  10. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
  11. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
  12. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    Yes, you can remove the rear "inner fenders". I can't imagine you needing to remove the front or rear, though. Put your tires on and cut a little at a time until they fit.
