anyone run a 400 small block?
Discussion in 'The Garage' started by WantedaDodge, Nov 4, 2005.
  1. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    Does anyone here run a 400 small block? I'd like to have 300 horsepower and 400 ft lbs of torque on 87 octane before I try putting 35's on my truck. I could cam my current 350, but I don't think a cam, intake, carb and headers is gonna get me there from a stock '84 350. The motor runs great, I know Edelbrocks performer pack with there fuel injection will make about 350 hp on 87, but that's like $3000 just in bolt on stuff. I don't wanna go there.
    I was wondering if maybe I should just build a 400 or maybe do a 383 stroker. I kinda hate to tear into my 350 since it runs so well, but hey, big deal, gotta make the ponys. I want something that will make the power, get decent fuel economy and run on 87 octane. Also, keeping it under 5,000 RPM would be good.
    Any suggestions? :confused:
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I'd get rid of those 3.08's first .
    I noticed a remarkable improvement just going to 3.73 from 3.08 ( cheap ) . I'd rather have 4.10's or 4.56's :D
  3. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    I have a D44 and 14 bolt with 4.10s ready to go in. But I know it's still gonna be doggy!
  4. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    loved my built 400 sbc. lots of bottom end power. just need good cooling system.
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    koldsimer is runnin a 400. that coupled with the sm465, he's got plenty of grunt down low.
  6. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Got a 400 in my 78 Jimmy. Previous owner went through the block with all of the upgrades, and it can light up the tires with 2.76 gears.. :haha:
  7. keifer
    keifer Registered Member
    Nov 1, 2005
    16
    MD-Phoenix someday
    Sounds like your current 350 has smog type heads. If you put a decent set of heads(vortec) on your 350, then install a cam, intake, headers, you can make 300 hp easy.
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    There's some tricks to making the 400 block cool better. Try searching some of the street car forums about it.
    Personally I think a 3.75 stroke in the 350 block is the better option. The flame speed of gasoline is fixed, so the bigger the bore the more stroke you need to get max efficiency out of the engine. Or you have to bring the max RPM's down. When crawling this probably isn't that important. It's the drive to the trail where this could be important.
    I think a 4" bore is about as big as it can get b4 the efficiency (read mileage) starts falling off. This is the reason Yuropeon performance engines tend to have a lot of small diameter bores. There are tricks that can be done with bigger bores to improve their efficiency, but I suspect that if you applied those same tricks to a smaller bore that it would work that much better than the bigger bore with the same applied tricks.
  9. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I've had 400's and loved 'em. Even built a 434 stroker when I used to mud drag. Just have a good cooling system and keep the rpm's down. I plan to replace the block in my Jeep (TBI 350) with a 400 whenever it dies and keep the injection system. Don't let anyone scare you away with old wive's tales.
  10. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I ran a 400sbc with a stock rebuild fow a while. Turned my 40s with 4.11 and 4.56s really well. It didn't like swimming though and spun a rod bearing. I could have fixed by I put the 454 in then
