anyone run a holley truck avenger?
Discussion in 'The Garage' started by wraenking, Sep 7, 2004.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    just ordered one off of ebay for 330 brand new. just want to here some pros and cons
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I am. I know nothing about carbs, and I've had quite a bit of trouble getting this thing to run right. I blame that on my own ignorance though, not the carb. I've still got a couple bugs to work out with the street driving, but things couldn't be better off road. I put it through some good tests, got it off camber so much that some friends had to hold my truck up. The carb just acted like it was on level ground the whole time. /forums/images/graemlins/waytogo.gif
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    One thing for sure was it sure wasnt bolt on and go.
  4. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    can you eleaborate?
  5. semper-k-five
    semper-k-five 1/2 ton status
    Aug 16, 2004
    326
    Tulsa, OK
    Holley tends to win the battle when it comes to who's better, Elderbrock or Holley...It just that holleys are a little more tricky to tune than eldebrock...ur definetly gonna what a rpm gauge and vac gauge handy....
  6. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Its a damn good carb, Ive got a 770 on my big block, you just have to take the time to tune it correctly, or take it to a shop and get it done.
  7. ben427
    Mar 10, 2002
    1,123
    And also, unless you have an aftermarket intake the throttle blades will hit the bores on a stocker.needs a squarebore to spreadbore adapter. But if you got an edelbrockperformer or similar it wount be a problem.
  8. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    hmm. i have a wieand intake, does that help?
    also, i thought the website said it was a spread bore.
    how much are those, and do you have a link?
    thanks
  9. ben427
    Mar 10, 2002
    1,123
    Yeah youll be Okay with that intake, it should bolt right to it /forums/images/graemlins/thumb.gif
  10. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    so i dont need the adapter?
  11. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    My TA is great!! After some fine tuning it runs like a champ!!
  12. ben427
    Mar 10, 2002
    1,123
    Nope you dont, you ought to be fine with that intake.
  13. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i bolted mine right up and went runs great!! but muddytazz will know more when he puts it in his burb /forums/images/graemlins/waytogo.gif
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    can you eleaborate?
    It was a while ago, but i think the fast idle was waaaay to high, had to adjust the a/f ratio, had a problem with the choke.
    I agree though, if you take the time and adjust it, it will work great, except for the loss of MPG.
  15. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    It can't be worse then my 350,000 mile stock 350 getting 7mpg....sometimes i feel like i'm feeding a BB /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
