anyone run onboard air?(co2)
Discussion in 'The Garage' started by spongeidys, Mar 30, 2006.
  1. spongeidys
    spongeidys 1/2 ton status
    Jul 6, 2005
    2,566
    Dillion, CO and Palmerton, PA
    was wondering if anyone runs co2 tanks for air on the trails....and if so how does it preform, what kinda tanks are you running and are there any precautions to running co2 on a trail truck?
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Funny, I was in 4wp the other day when I saw the brochure for those co2 air tanks. I asked how many he had sold. He just gave me a lost puppy look... he didn't even know they had them.
  3. spongeidys
    Jul 6, 2005
    2,566
    or anyone have any links readily avail to a york compressor setup?
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I have ran a CO2 tank in the past and they work great. I just bought a 20# CO2 bottle and put a regulator and I run tools or air up tires as needed. I'm sure if you do a search for CO2 tanks you will come up with TONS of info about them.
  5. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Love It
    Definitely do a search there is a lot on this topic.
    I've been running it for a couple of years and I'm happy with the setup. I used a fire extinguisher bottle as it was readily available, and I liked the idea of a rugged bottle in the truck vs the lighter, thinner tanks used for draught.
    Some things to consider; use an appropriate regulator and guages designed for the pressure and gas.
    I found that in the winter the bottle tends to freeze up. I now use a long hose and leave the bottle in the warm truck.
    You can't reliably tell how much is in the tank due to the nature of the gas unless you weigh the bottle (I just throw it on the bathroom scale).
    There is a lot of work energy available, and no moving parts to fail. It is way cheaper though you do have to refill the bottle periodically.
  6. spongeidys
    Jul 6, 2005
    2,566
    just from the replys here im pretty sure im gonna run a co2 tank, i can get big steel tanks for next to nothing from friends that work at a paintball place then spend the money to put into a proper regulator set up
  7. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I run a 20# when I am on the trail
