anyone run Pitbull Maddog 35x14.50R17s?
Discussion in 'The Garage' started by WantedaDodge, Jan 29, 2007.
  1. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    Considering these tires over 305/70R17s Buckshots, but I'm worried as to how much trimming I'm going to have to do with only a 4 inch lift. I was planning on installing a 1 inch body lift in a month or so.
    My truck is a DD/mild trail/mud/camping(1000 mile trips). What's the consensus?
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    35's shouldn't need much trimming at all with a 4" lift. And with a 1" body lift it'll be even less. But if you're flexing it out all the time, you'll want to trim more just to be safe.
  3. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    probably won't be doing a whole lot of flexing with my 4 inch leaf springs and blocks in the back, but this is good news!
  4. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,851
    280
    Truckee, CA
    width will be a problem when flexed....your not gonna stuff that in your fender no matter what backspacing you run
  5. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    I rub with 33-13.5-15 Pit Bull Rockers with 4 inch backspacing with a four inch lift:D
  6. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    well, don't think I'll be running 14.50s then!
  7. barneybasher1010
    Sep 25, 2005
    908
    PORTERVILLE CA
    just:hack: :grind:... I will be doing that after my 3/4 ton swap:D
