Anyone Run Propane
Discussion in 'The Garage' started by 78Suburban, Jul 8, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I ran up on gotpropane.com and am pretty impressed with the looks of the products they sell. I was considering perhaps converting my 350 to propane years down the road (when I get rich.) It just looks kinda interesting to me. I was wondering if any of yall run propane as your primary fuel and what you though about it. How does it affect horsepower/economy? what are the pro's and con's?
  2. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    I've never heard of propane being the sole fuel for a gas motor.... propane itself is less powerful than gas. When you add a little propane into diesel or gas it somehow bumps power. Thats about as far as my propane knowledge goes.
  3. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    check out www.austink5.net a bunch of guys run on just propane over there. there all trail rigs but they have a good thread in there tech articles forum and most if not all ur questions will b answers. good luck i wana do the same on my trail rig when im rich
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I wouldnt do it if its your DD. You would have to have a HUGE tank to be able to go any miles with it. Propane is a higher octane fuel then gas. The componets to go to propane are only about $400.
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    it's not my Daily driver. would my motor have to be internally modified to compensate for the slower burning fuel? where can you get the components for $400 (they are like $1000 at gotpropane)? I wish I knew how it would compare economically to running regular gas.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
  7. muddyblzr
    Nov 2, 2004
    623
    dammit chris you beat me to it. i forgot a link
  8. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    Converting to propane is not worth the hassle anymore. Propane prices have gone up faster than gasoline prices. At one time propane was little more than half the price of gasoline, but after gasoline prices started skyrocketing in late 2001, the energy companies did not want a wholesale propane retrofit movement to begin, so they jack up the price of propane to about almost as much as gasoline.
    Right now propane is only about 10 cents a gallon cheaper than gasoline. It would take decades of driving to get your Return on Investment (ROI) anymore. There is about a 20% horsepower loss with running propane as compared to gasoline. You can make up for that 20% loss by increasing compression, and installing a camshaft with lots of duration. Since propane is a high-octane fuel, it likes high compression. You can also get special camshafts for propane engines as well because propane likes lots of valve timing overlap.
  9. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    what is the highest compression you can run with propane?
    seems like an alternative diesel.
  10. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    Propane has a prospective octane rating of about 114, so the sky is the limit. 14:1 would likely be no problem with propane.
  11. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    sounds like a good reason to build a 427 stroker..... :thinking:
  12. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    113
    Fresno, CA
    Propane
    August 2005 issue of Off-Road magazine has an interesting article about the propane conversion. Seems to be mostly positive, but, what mag article isn't?
