Anyone runnign Edelbrock TES headers?!?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Nov 26, 2001.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    From my understanding, these headers come with a Y- or crossover-pipe. How does this pipe clear the front driveshaft? Is it under or over it? Or is it further back and not an issue with the front driveshaft?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    It actually fits to close for a 4" lift. Mine started to rub so I just had my exhaust shop install a new crossover that fits snug up against the t-case crossmember.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  3. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    I am running a Edel TES. The x-over is below the driveshaft...but it isnt really a problem because you can adjust the angle to which the crossover pipe attaches to the headers...all you have to do is angle it down a little bit and its all good. Doesnt take much effort to flex your suspension a little to see if it rubs etc. =)
    Jason
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  4. Esteban86K5
    3,712
    Bakersfield, CA
    Jason has a point as you can adjust it slightly but if you do drop it down to low, it will want to "FEEL" the rocks a little more. That is why I went with rerouteing(sp?) it further back and closer to the t-case. No overhang now.[​IMG]
  5. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    Well...its not an 1/16" lower than my x-case skid plate...and its way higher than the bottom of the 10b up front...so I figure its out of the way enough. =p
    heh heh. Of course, if I was a welding guru...I woulda rerouted it long ago. ;)
    J
  6. purple89jimmy
    purple89jimmy Registered Member
    May 29, 2001
    75
    I run em', but had to fab a new crossover because of the 6" lift. It is in the way BAD, even 4" would be too much before you need to reroute it.
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I have a 6" lift and the TES headers... got the headers on but the y pipe that came with it needs creative help so it doesn't rub anywhere....
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I keep trying to lose weight, but it always finds me!
