Anyone running 200R4 trans?
Discussion in 'The Garage' started by gm guy, May 25, 2004.
  1. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    Any comments?
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    never heard of a 200R4. Do you mean 700R4?
    nick
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    200R4 is the OD out of cars like the Buick Grand National.
    They can be built tougher than most 700's but I think to use it you have to go divorced tansfercase.
    I've heard talk of this before but I have no idea if anyone is running one.
    I think that it has better gearing than a 700 but I'm not positive.
    I just know that they are big with the GNX guys.
  4. richheezee
    richheezee 1/2 ton status
    Dec 29, 2003
    116
    San Jose CA
    nick
    200R4's came in GNX's (Turbo Grand Nationals) and Turbo Buick Regals. They run in the 9 sec. range.
  5. gm guy
    May 1, 2004
    151
    They are the same length as a th350 so I thought it would be a easier and better switch than the 700R4. Anyone have info on the divorced transfer case issue?
  6. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    They actually came in a lot of different cars in the late 80's. They are a BOP pattern tranny. They are a direct replacement for TH350 and don't have as deep 1st gear (would think in a 4wheel drive deeper first gear would be desirable) They were the first to be built up compared to the 700r4 but the aftermarket has steped-up and they are comparable when built. I am not sure if any were used in trucks. I plan on putting one in my camaro, here is a very informative site I found on it.
    http://www.montecarloss.com/SSThunder/drivetrain.html
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    It's actually a 200-4R.
    It was put in fullsize cars and never was hooked to a transfer case. The reason why people build it up is because the internals are a bit beefier and the gear ratios are better spaced (even though the first gear is taller).
    first: 2.74
    second: 1.57
    third: 1
    fourth: .67
    700R4
    first: 3.06
    second: 1.63
    third: 1
    fourth: .7
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you will have to run a diversed tcase because they do not have a removable tail shaft like the 700r4, th350, th400
  9. gm guy
    May 1, 2004
    151
    Using a divorced transfer case would require total driveline mods right? Doesn't sound like I want to use one, th350 it is!
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, it would require driveshaft mods. you would have to make a drive shaft from the tranny to the tcase, lengthen the front, shorten the rear. if youn have a blazer its not posible, because the rear would be way to short.
  11. gm guy
    May 1, 2004
    151
    Yeah, I don't want to even go there! Thanks /forums/images/graemlins/peace.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    People are running doublers in Blazers. If that works, a divorced transfer case is not impossible.
  13. gm guy
    May 1, 2004
    151
    Thanks but I would rather not even get into that. Customizing drivelines is not something I plan on learning or experimenting with. Kudos to anyone who does though! /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/bow.gif
  14. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Sorry for using "search" and reviving an old thread...... :D
    Has anyone used one of these in a 2WD application? Like a tow rig?
    I have seen a lot about them in the car mags....same length as my existing TH350 (in my 2WD Burb), so I thought it MIGHT be a slick way to get an OD gear without major changes.
    4L80Es are sweet, but VERY long and plenty of these -> $$$$ if you need a standalone controller.
    :thinking:
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    A guy on this site did it Clicky
    Seems easy , move the crossmember back , your shaft may need fabbing if you have the long th350 , speedo cable hooks up etc .
  16. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I've been reading either Super Chevy or CHP and came across an article on the 200r4.
    The Grand National valve body was apparently the "hot setup" according to the article too...but they said they are getting hard to find (and expensive when you do!) Apparently, someone is now making a similar part so you don't need to pay the big bucks for the GN item.
    Like anything, I'm sure a built 200r4 is still going to cost some bucks....but the GV Overdrive is ~$2600 these days....that's not a trivial solution either.
    :yikes:
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You could also go 700r4 , which contrary to popular belief does not just blow up the second you put it in gear :D
  18. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    They work fine in a Suburban tow rig to my surprise.. We put one in my buddys 89 2wd Burb 2 years ago and it's still going strong.. He uses it as a DD that requires him to drive sometimes 50-100 miles one way depending where he is working beings he is in the logging buisness.. He has also taking it on 4 road trips that he went over 1,000 miles one way.. It is also used to pull his 19 ft fishing boat almost once a week during fishing season when it's 100 degrees.. Not counting pulling car trailers and other utility trailers for work.. So I think I can say with confidence that after all he has put it thru I'm impressed even though I had my doubts about it when we put it in :D
    He got it to replace the 700r4 that went bad and needed a tranny right away and he found a guy he knew that had the 200r4 for $100 bucks :eek1: That was another reason I had my doubts but he couldn't find a 700r4 so we went with the 200r4.. The only thing that was not a direct bolt in was the crossmember.. We had to move it because the 200r4 did not line up with it in stock location.. It did throw his speedometer off by about 12mph but he picked up a speed sensor box and that got him closer to about 3-4mph difference.. If it quit tommorow I couldn't say anything bad about it because it has more then done it's job time and time again..
    So if you were thinking about going that route then I say go for it if you can pick one up for a good price.. I was doubtful at 1st but now I'm a believer so if I was in that situation I wouldn't hesitate to run one myself :waytogo:
