Anyone running 35's and 3.73 gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Nov 14, 2000.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Anyone running 35\'s and 3.73 gears?
    I am finishing my axel rebuild and well, my cash is gone. So I am stuck with 3.73 gears. I want to run 35's or 36's and have decent performance. I dont plan on any mud races or off road challenges but I would like to travel around and do some serious off roading. I have a Detroit locker in the rear and plan on getting a lock right in the front so I feel I will have adequate traction but if the power is not there I will have to wait for a little while before I can complete my project and I cant wait!! So if anyone can give me their opinions on my situation or any experiances you have had please let me know!
    Thx
    Brent
  2. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Re: Anyone running 35\'s and 3.73 gears?
    What trans/transfer case combo are you running???
    I have a sm465 4 sp and a np208 they both have good low gears. I run 35's and i have 3.42's in the diffs.
    Bill Innes
    88' Jimmy
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I'd like to know how this works as well... will have my lift completed and 35's on this saturday... I have the 3.73 gearing... Anyone have some info...
    Um... yes officer I know it's too big...
  4. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    700R4 Tranny and 208 case....
    Brent
  5. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    My wifes Sub runs 3.73s with a 350trans.With 33" tires it has plenty of power to move that thing pretty good.It has a 406 smallblock so it has the power.With the overdrive trans you have you may want a little lower gearing other wise your engine may run below its power range on the highway.Brady
    '73Beautiful Disaster http://beautifuldisaster.coloradok5.com
  6. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I've got 35" BFG's with 4.11's and think that my RPM's are a bit high at freeway speeds, and I used to have a Blazer with 35's and 3.08's which seemed only slightly higher geared than I would have liked. So I don't see that you'd have any problems with 3.73's and 35 or 36's.
  7. Texan
    Texan 1/2 ton status
    153
    Leander, TX
    I run 35's and 3.73's with an OD tranny and love it. I'm realistic; 98% of my driving is on road and this combo suits me. If I did alot of towing or hardcore offroading (not gonna happen as long as it's my daily driver) I would probably step up to 4.11's...
    <font color=orange>STEVE<font color=orange>[​IMG]
    89 Blazer
    67 Camaro 468
    68 CamaroSS 327
    98 GTP
  8. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    my 74 has 373s and i have 35s. i dont like it. top freeway speed is 60 and i still get 10 mpg at best. so why not have the fun of lower gears? btw 350/350/203
  9. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Hey Misfit, 60 MPH top speed? I have 35's with 3.73's and the SM 465 4 speed and my truck will pull 90 MPH easily, tops out at about 100. I pull a 5200 lb trailer every summer. My cruising RPM is about 2400 RPM on the freeway, and my mileage isn't bad at all. Overall I like the 3.73's and 35's, it works well for me.[​IMG]
    Rene
  10. CK5
    May 19, 1999
    21,622
    701
    CO
    I used to run 3:73 with 35" tires (700R4/NP241), it wasn't to bad around town but really sucked in the mountains, then I went to 4:56 with the 35's and it was about right, now I have 4:10's with 36" tires and it sucks big time, after the 60 swap I'm going to 5:13 for some major scoot up the mountains. Go to www.ring-pinion.com and they have a calculator that you can get your ideal RPM range from.
    5,000 Pounds of American Rolling Steel
  11. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    So there is no power for climbing steep inclines...I do alot of off roading in the snow, and trail riding..maby an occasional mud bog (nothing like the pic of Y2K5) maby 2-3 feet deep. I certainly do not want to get stuck and I would like to make it out to the next get together in Colorado and perform well... I may go with 4.10's, I found a front set I may get cheap and I if I do I will look around here for some one with a 14FF set.
  12. Jason73K5
    592
    Fresno, Ca
    I used to be able to get close to 100 with 3.08's and 35's and have no problems doing 85+ with my 4.11's. It sounds like you might have engine problems. You should be able to get a bit better mileage than that too.
  13. Jason73K5
    592
    Fresno, Ca
    Remember, power for inclines depends greatly on how your engine and transmission are built too. I've never had any major power problems with mostly stock 350's.
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have 33s with 3.42s and its OK. I still have some power down low, but I can't peel out or anything. It has a lot more power higher up, so I get good acceleration in "D" around 50-75. I have a 700R4 and NP241. Its really good for passing on the highways
    90K5
  15. 89K5
    89K5 1/2 ton status
    Jun 14, 2000
    134
    Maryland, PA on Weekends
    I have 35s w/3.42. Most of my driving is on the highway, so its not bad. When I do get a chance to go 4wheelin, it sucks. When its my 3rd vehicle I'm changing to 4.56. But the odd thing is I only get 12 mpg on 35s w/3.42. I thought it would have been better than that. Maybe because I have to mash the pedal to the floor to get going!
