Anyone running 44's with only 8 inches of lift? PICS ADDED!
Discussion in 'The Garage' started by Mr.Chevy4x4, Mar 4, 2007.
  1. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I just traded my 39.5 boggers for some 44 tsl's and I am wondering how much trimming I'm going to have to do???? I have 6 inches of suspension lift and 2 inch body lift. Some pictures would be great.
    Thanks,
    Mike
    UPDATE:
    OK, so I didn't use a sawzall, but they are done! I lifted the right rear with the forklift and got 40+ inches before lifting the left rear. The left front was stuffed! Almost done with the roll cage too. 2 weeks til gray rock and making progress!
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
  3. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
  4. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    8" is more than enough, just get rid of the entire body.
    j
  5. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    I've seen that post ....I'm not a newbie. Look at my join date and then look at yours....
    I was looking for someone with the same setup, and pics. I didn't find what I was looking for in that post.
    Thanks for your useless post though! :)
  6. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,859
    282
    Truckee, CA
    Really, w/ 8" + 2" body, you have a lot of clearance ot start with. Yes, you will need to trim.....but i doubt it will take much.
  7. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Just :hack::grind::weld::hack::grind::weld:that [​IMG]!!
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Join date has nothing to do with it. You should`ve said that you`ve already done research, maybe that would`ve prevented my "useless" post....
  9. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    how much you trim is going to depend on how you wheel it. I have 8" of spring and 3" body lift. The front tires rub when flexing offroad. I have gotten the rears to rub but only on a RTI ramp. I do not run inner fender liners, the tires rub on the cab. I hacked the fender all the way back to within 2" of the cab. If you move the front axle forward that would help.
    I'll try and remember to get pics when I get home.
  10. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    That would be great. I would appreciate some pictures. The truck is a rock crawler and I've got the suspension where it works pretty well. I hate to change it now for more clearance. I could get another inch out of the front with some zero rates but I would have to reduce the diameter of my tierod. I have high steer with full hydro steering and the tierod is close to the springs as it is. I could go with a smaller diameter DOM and heim joint and maybe clear a zero rate block if that extra inch made a big difference. I don't mind cutting up the sheetmetal, but I am thinking the front of the cab might be in the way. I'm not too crazy about cutting the cab.
    Any constructive input would be appreciated.
    Mike
  11. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I am running 6" of lift in the front with 42" IROKs. I also have 6" bumpstops up front. This keeps the front springs from inverting too much and helps keep the tires out of the fenders. The rig scored 1000 on a 20 degree RTI ramp.
    Here's a pic of the latest round of trimmin'.
  12. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    couple of pics. the first one is 8 spring and 3 body with bushwacker cutouts. the second is how it's cut now with the same lift. the third is 8 spring and no body.
  13. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    you werent kiddin about no body in the third pic.:haha:
  14. Speedo
    Speedo 1/2 ton status Premium Member
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    How about 4" lift on a Suburban and 47" tall tires, my wife's rig. She just took the body off and built her own.
    Gus
  15. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    lol thats sweet
  16. muddindirty
    muddindirty Registered Member
    Aug 24, 2006
    46
    Down South Louisiana
    6" skyjacker springs front and rear, No blocks, with a 3" body lift. Been seriously thinking about going 10" springs in the front with a shackle flip in the rear to get rid of the body lift but it's just a mud bogger and works like it is, unless I come across a good deal. It doesn't see much flex. anyway.http://coloradok5.com/forums/attachment.php?attachmentid=41606&d=1172718464
  17. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    where did u get the 6" bump stops? might be a good option in my case even after the fender trimming...
  18. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    NOW THAT'S A KEEPER!!!!
    and I mean rig and WIFE!!!! :haha:
    now to get my wife to want her own truck on 47's :wink1:
  19. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Here's a shot of mine.
    5-6" kinda hard to say really.
    No inners, More trimming needed, Axles moved fore and aft and narrowed. Everytime I so much as think about hitting a bump, I crumple the oil filter so haven't to to do much with it as of yet!
  20. greythorn3
    greythorn3 1/2 ton status
    Oct 14, 2002
    174
    Anchorage alaska
    Ha 8274 Winch
    Hey is that 8274 really enough for that rig? just curious????:confused:
    Ray
    ALASKA
