Anyone running a 14bolt with disks and 15" rims?
Discussion in 'The Garage' started by jjlaughner, Jun 3, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Anyone running a 14bolt with disks and 15\" rims?
    /forums/images/graemlins/ears.gif
    Grinding?
    Pics?
    I'm going to stay with a 15" rim and probley going with a 14bolt rear and 8 to 6lug adapters (maybe... stil having a hard time thinking about the rim not being directly attached to the rear lugs /forums/images/graemlins/blush.gif)
  2. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Re: Anyone running a 14bolt with disks and 15\" rims?
    Only steel rims fit over 3/4ton stuff when using a 15" rim right?
  3. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    im runnin 15x8 with 4" backspace with a 14 bolt and disk brakes...very minimal grinding..im talking less then 5 minutes per side.....used misfits caliper brackets and 1/2 ton calipers...
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I didn't have to grind at all on my set up with 15x8 with 4.25" BS.
    Steel wheels are NOT the only wheels that will fit over 3/4t stuff, but I have yet to find a 15", 8on6.5 wheel that is made of aluminum. So if you wanna stick with 15" wheels on 3/4 ton stuff, then yes you are limited to steelies...
    Chris
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I am running discs with 15" rims, 15x10 steel and 4.25" backspacing.
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Same here. No grinding for the rear.. very little on the D60 front. /forums/images/graemlins/tongue.gif
  7. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I am running a 14bff with tonyp's 8-6 lug adapters and 15x10 M/T classic II wheels with 3.5" backspace. No interference whatsoever. /forums/images/graemlins/waytogo.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I had to grind the crap out of my 60 front.
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    yes, we had this discussion about we're running the same rims and backspacing, yet you spent hours grinding your D60 and i spent 10 minutes...
    i just found another oppertunity to rub it in, and had to... thats is all. /forums/images/graemlins/histerical.gif
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What wheels do you guys have?
    I have 15x10 Eatons with 3.5"BS. I did most of the grinding on my D44 calipers with a file...really just getting rid of the casting flash.
    I don't have the $$$ and even though I don't want to grind the calipers on my 60 I think I am going to have to /forums/images/graemlins/frown.gif
  11. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Chris
    I have seen at least 2 sets of 15" aluminum wheels in 8-lug. They were made for old drum brake axles. They will not fit over any 8-lug caliper. Aluminum rims are alot thicker then steel rims...and because you can't increase the OD on a 15" rim you have to decrease the ID.
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    How do you like the adapters? /forums/images/graemlins/ears.gif /forums/images/graemlins/thinking.gif
  13. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I have 4" backspaced Barts...
    I had about 5 minutes of grinding...
    I just knocked off some slag off the caliper..
  14. blasterD
    May 24, 2003
    410
    Anchorage Alaska
    I like Tonyp's adapters. They fit well. All hardware is included in his kit. I haven't had any breakage yet so they must be pretty strong. I would definitely recommend them if you didn't want to change your 6-lug front. I also like the little bit of extra width. It was just enough to keep the wheel outside the disk/caliper. I could run 14" wheels with 3.5" backspace and still have no clearance issues. I had just bought new wheels for my d44/12b when I found a killer deal on my 3/4 ton axles. Rather than dump a bunch more money on new wheels, I swapped the new axles (they were 4,09s instead of 3.73s) in and kept my wheels. The only drawback I can see is that I still have 1/2 ton brakes in the front. I did a disc brake swap in the rear so I don't have any braking problems. Also Tonyp is awesome to deal with. He quickly answered e-mails and I got my parts quickly. He was also very helpful on the phone. /forums/images/graemlins/waytogo.gif
  15. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Since I would be doing the disk brake swap is that an after market hub that adds a little width but is 6lug for the 14bolt? Wouldn't really want something 1-off because of the price but I would fell better if I knew that the rim was connected to the axle instead of to an adapter attached to the axle. I like the idea of the rear being wider, I've always wanted a better stance I just can't get past not having that rim/axle contact, esp on a DD that sees mainly Highways. /forums/images/graemlins/crazy.gif
