Anyone running a 6" lift with no major vibes?
Discussion in 'The Garage' started by 8_YOUR_H2, Jun 3, 2002.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Anyone running a 6\" lift with no major vibes?
    I know I need to get longer driveshafts but I just cant shell out the cash on CV. So I would like to get some input from anyone with a 6" lift and no CV. Is there a lot of bad vibes? I plan on lowering the tcase with the stock spacers to help.
    Any info is greatly appreciated.
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Re: Anyone running a 6\" lift with no major vibes?
    Hey I'm running 6" lift w/38's still haven't lengthed my drive shafts and no vibes at this point yet, but I'm still gonna use the CV setup just for more durabilty and better angles.
    Just my OP or .02
    Hmmmmm
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I have a 6 in and 38s also, and I havent noticed any vibes worth mentioning. Is it the tires or the shaft? I have no clue. It seems worse at lower speeds (under 30 MPH) so I think the bit I have is in the tires. My case is dropped 1in. BTW.
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I have 6'' lift with no more noticeable vibes and no c/v. I lowered the T-case 1'' and the rearend is ''shimmed'' up towards the T-case because of the shackle flip. The only vibes I get now are from my severely chunked and out of balance tires (need to trim a lot!) I will be getting a c/v before Blazer Bash so I can raise my T-case back up.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am with the others.. 6" lift no major vibes! And I didn't lower the t-case.
    However I do need to replace the front u-joint on the rear shaft about once a year.
