Anyone running a performance cam
Discussion in 'The Garage' started by 76_Cheyenne, Jan 21, 2003.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I've just started looking into maybe getting a more radical cam for more juice. Anyone got one in their rig and care to share about it? What brand did you get and which one is best for performance offroad and on road.
    thanks /forums/images/graemlins/truck.gif
  2. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    as far as brands I like crane or comp, I dont like edelbrock they seem to soft. as for the grind it depends on what your after high rpm's or low.have you done other mods that would be helped or hinderd from a big cam, you need to match it all up.
  3. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    well, im going to put an edlebrock performer intake on and a K&N 14" filter assembly. I also have a set of performance headers on there.
    I drive my truck on the freeways around 2700 at about 60-65 miles an hour with my 4.10's. I want someting that works well around that RPM but I use my rig offroad and need lots of torque. Plus anything that helps with fuel is a bonus. /forums/images/graemlins/truck.gif
  4. great scott
    Dec 31, 2002
    333
    Utah
    sounds like your headed down the wright road. edelbrock makes a cam to match that manifold but i dont like there cams so i would find another with a simalar grind. but any mild cam should do you good.
  5. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    I have used Comp Dual Energy and the 4x4 Extreme cams in truck engines with good results. Don't remember the exact specs, but the lift was in the neighborhood of .442/.465. My brother is running the next size larger in his 400. Great low end.
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Cam choice really depends on what you want to do with your truck. Sence I'm going to be on mostly trails in the forest, I'm going for low end torque. I'm really intrested in These [​IMG]
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I've had good luck with a crower "Baja Torquemaster" model cam. I don't know if its still made but worked great in a couple of SBCs I ran em in. /forums/images/graemlins/thumb.gif
  8. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    I'm running a Comp High Energy 268 grind. it seems to provide good low end. this is in a 454 with edelbrock 750cfm,holley intake, ported and polished heads, keith black pisons, balanced.
  9. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    blazerkid does the HE268 give you a little lumpy idle in a big block?
  10. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    How bout 268 with 88 TBI 350.Need to do engine this year and want mure than stock. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  11. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I ran that cam in my 400 and I liked it. I run a slightly higher cam in my 454 now. About a .510 lift or so. Didnt notice a lose of low end either.
  12. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I have a Crane Energizer 282H06, it is a 470-lift, 282-duration, it is a 106 lobe seperation. It's what alot of people used to call a 3/4 race cam, and actually it said 3/4 race on the end of the box when I got it. I really like the way it sounds and it has alot of power as soon as you touch the gas. It would probably be a little much for what you are needing. My truck is driven almost only offroad and has a built 400. I would recommend that you take a look at the Crane Energizer cams, I have had good luck with them and they are reasonably priced, Jegs has the cam and lifter kit for $109.00.
  13. TheBlazerKid
    Apr 26, 2000
    259
    Raymond, Washington
    It gives teh big block a noticably lumpier Idle, yet it is still smooth enough to be able to lug down to 500 RPM if need be. It also provides really powerful low end.
