anyone running a shackle lift up front
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86 4door, Dec 9, 2002.
  1. 86 4door
    86 4door Registered Member
    Nov 28, 2002
    15
    pottstown PA
    is anyone useing a shackle lift on the front? if you are what brand- how much lift? thanks in advance
  2. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    1.5" lift (3" longer) Worrior Products. Don't like them much, they make a clunk under hard turning and require shortening the bushings and sleeves. Pretty strong tho, not worried about that. Turning radius widened up after the install also.
  3. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    reread, sorry. Yes you can but too much will lead to "death wobble"
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    I am getting 3/4" out of a set of shackles. This wasn't enough to cause driveability or front driveline issues as everything is fine.
    I made them out of some thick steel and they have more than one set of "top" holes so I can adjust the height by about 1/2" or something like that. I forget what these pieces were originally intended for, but I got them for something like $15 with most of the holes already drilled right and zinc plated. I use them with ORD greasables.
