Anyone running an Atlas II transfer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5DRAGER, Jan 9, 2002.
  1. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Was curious if anyone was running an Atlas II transfer case? And if you where would you recommend or not and why? Thanks
  2. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    DBlazer has one and is very happy with it. I'm going to run one in my Blazer. You definitely want to get the 32 spline upgrade for a fullsize.
    Chad
    '73 Blazer,383,400,Atlas II,D60/14 Bolt,traclok/detroit,39.5 Swamps <a target="_blank" href=http://members.aol.com/fileholder2meg/projblazer.html>Clicky</a>
  3. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    It's on my Christmas list! Moose is planning to. As long as you have less than 900 horsepower. The coolest thing is it bolts on with no mods except maybe driveshaft addjustment.
    If you knew the truth, you too would be against marijuana prohibition!
    Blue '74 K5 Blazer Topless W/ 35 BFG Muds (See profile for pics)
  4. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I have one in my '87 K5 and love it. The twin stick is great, and helps with the front locker on rocks. It is quite pricey with the case, 32 spline upgrade, and adapters (if needed). I love the low range capabilities and the overall length, although that really does not matter in a fullsize. I also like the ORD doubler for the fact that one has the choice of two low range ratios, and can be converted to twin stick also, like any other NP 205. If you could find the parts needed to make the Doubler easy enough (look on the for-sale board) it might be worth it to go with the Doubler. I don't think that strength is an issue with either set-up. It mainly comes down to personal opinion. Just my $.02.
    '87 K-5 w/ 350 TBI, 700r-4, Atlas II, D60 & 14Bolt, 6" susp., 1" ORD body, 35" Claws
  5. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Thanks for the replys everyone. Just starting to look into different options for lower gearing.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    You know what would be cool?
    ORD designing an adaptor to mate the Atlas II t-case behind the ORD Doubler.
    Use the Atlas in place of the 205 t-case.
    Let's see....that would give you about almost 6.1 ratio on the low ranges!!! [​IMG] [​IMG]
    Anybody wanna bug Watson to making some gizmo to mate the Atlas to the Doubler? [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  7. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Couldn't that be done by ordering the Atlas with a 32 spline input, like one to replace the 205?
    Actually, you could get a 8.3:1 low.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
