Anyone Running Electric Cooling Fan(s)??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ford_assassin, Jan 19, 2004.
  1. ford_assassin
    ford_assassin 1/2 ton status
    Nov 8, 2003
    101
    Bakersfield, Ca.
    I am considering swapping out my stock clutch fan for a electric fan setup.
    Anyone running this?
    I just wanna be able to keep everything cool, while saving alittle HP and mpg.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I have 2 electric fans out of a 2000 toyota camry but I haven't installed them yet. I am still wondering if they will pull enough air to keep my 400 cool.
    Hey, by the way I was down in Fresno Friday till yesterday. /forums/images/graemlins/rotfl.gif
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    do a search for windstar fans on here.. they pull pretty well.. so do taurus fans if i remember correctly.. /forums/images/graemlins/thumb.gif
  4. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    I have one 16" right now, but it doesn't pull enough to keep the engine cool under heavy load conditions like wheeling up big long hills and such. Keeps it cool on the street though just fine even idling in a lot of traffic. I think i'm going to add another 12" fan or something as an aux. fan with a switch to it.
  5. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I'm running a single 14" 2950cfm fan and it works great!
    Bill
  6. ford_assassin
    Nov 8, 2003
    101
    Bakersfield, Ca.
    Bill
    What brand (and part number) is that?
    Thanks.
  7. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I run a set of fans off a lt1 camaro, They kept my blown 355 in my ta cool and have no problem keeping my crate motor cool. They pull lots of air only thing is they are loud.
  8. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I run twin 12" fans on my daily driver and it stays cool. Well, it doesn't go higher than 210.
  9. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I run the Winstar setup on my 71 ElCamino and will be installing a set on the blazer later this spring. Sandman has also installed the Winstars. The Mark-VIII single fan will pull over 5000CFM by itself but its loud /forums/images/graemlins/eek.gif
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    How about camry fans? Has anybody used them? I haave 2 camry fans and I am wondering if they can pull enough air.
  11. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Hey Cable... I was searching the Pick-n-Pull(off the 99 at Jensen ave)in Fresno a while back and I saw a buttload of V-6 Taurus with the twin fans still attached... might be a good starting point...
  12. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Bill
    Thanks.
    Here is the web site and part number.
    Perma-Cool
    Bill
  13. 88Silverado
    Mar 13, 2003
    2,664
    I dont have any experience with the Camry fans.
    The thing I like about the Winstar setup is they are almost the exact size of the radiator and only minor trimming is required. Im sure there are several different factory fans you can use. Its just how much of the radiator do they cover and ease of installation.
  14. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used the windstar fans and it was very easy. The only trimming that I had to do was to cut the shroud some to clear a radiator hose that goes to the radiator instead of the water pump. Without that, there would have been no trimming. It fits almost perfect with like a 1/2 to 1" gap on the bottom is all.
    I havnt had a chance to really use it yet but is does move some real air sitting in the shop. /forums/images/graemlins/rolleyes.gif
  15. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Are you running a fullsize radiator? How did the LT1 fan setup line up? Any pics?
  16. dyeager535
    26,982
    191
    Not that you asked me, but I've got the same fans (or maybe mine are LS1's...only difference is the "shroud" is cut out in places for better airflow on mine, "other" style the shroud is "solid".) out of F-bodies.
    Just worked out the fabrication details with my dad. The LS/LT1 fans are a bit narrower (maybe 1-2") than the "fullsize" gas radiator, and a few inches shorter than the radiator. They use goofy mounts (2 "hooks" on either side to hold it in place) and across the top, one "bar" that apparently fits in between cast "fingers" that protrude from the top.
    Going to take two straps of metal from the factory truck shroud bolt holes in the upper radiator supports to the bottom of the core support, and angle iron across the bottom of the core support, which will bolt to the lower two stock shroud holes. All three pieces will be welded together obviously. Lower part of the shroud is perfectly flat, apparently the sides and upper portion of the shroud are all that kept it in the f-body.
    Not sure what I'm going to do to hold the shroud "down", but I'll probably use round stock from one side to the other, weld nuts to the backside of the "straps" so as not to need a wrench on the backside. I could of course forego all this work, and just fix the fan in place, and unbolt the whole assembly when removal is necessary.
    Would have loved to make it out of aluminum, but local store doesn't carry it, and it would be more expensive...not worth it for the weight penalty on a 5000lb vehicle. Cast iron to aluminum intake swap covered that anyways. /forums/images/graemlins/rotfl.gif
    Probably more info than you needed to know, but as a "just in case" for anyone else considering the LT/LS1 fans. I think the windstars or other larger afn assembly would probably be easier to deal with. The LT/LS1 fans are designed to not use any bolts to secure them, and it makes mounting more difficult. I've got a fan with a broken mounting tab, so I know that it's possible, and drilling into it will only weaken the plastic.
    Also, the fan wiring comes off the drivers side, which for us is a problem if you want as short wiring as possible. I think the plugs are interchangeable on the motors, which will allow you to route the wiring to the drivers side, and this is likely the easiest "problem" to work around.
  17. 88Silverado
    Mar 13, 2003
    2,664
    Heres a picture of the winstar fans on my Elcamino.
    The radiator is the same size as my Blazer.
  18. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Where did you get those Winstar fans?
    Bill
  19. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    what year windstar are those from?
  20. 88Silverado
    Mar 13, 2003
    2,664
    I bought 2 sets from my friend. Got them at a bone yard.
    They are 1995-1998, You can buy them (or other furd) fans new at this link
