Anyone running Hedman headers w/a/c and p/s?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Jan 25, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I got some basic Hedman Headers for my new 350. I got the a/c bracket for them, but that only appears to work with the long a/c compressors. Mine is the short one. The original bracket mounted to the front two header bolts. In addition the p/s bracket attaches to the a/c one.
    Does anyone else have this setup that can tell me how you got it all to work? Any help you can give would be appreciated before I go custom fabricating.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I am running this setup. You have to cut off one leg of the bracket where it mounts to the header.
    I then used an old metal shock bushing/spacer to hold the bracket against the header. You can also use 4 nuts one size larger than the bolt. I did this for a while too.
    I can take a picture when I get home tonight. It will be a little late. But I'll try to help in any way I can.
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  3. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    So, I am assuming you cut off the back leg? Then you mounted only the front header bolt? Is there any problems with stability or strength with this method?
    Brian
  4. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Correct.
    None yet, and have spun the motor to 6800rpm. Works fine for me.
    John
