Anyone running Hummer bias tires?
Discussion in 'The Garage' started by LKJR, Oct 8, 2003.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Just curious to how they handle on the road? heard they tend to wander a lot.
  2. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I've got a set that are about to go under my junk. I hear they're loud and get the vibes for the most part. I got 'em cheap to hold me over till I can afford something betta'. Probably gonna run the TRXUS again.
  3. Skroo
    Skroo 1/2 ton status
    Jul 13, 2002
    137
    Houston, Texas
    I just lifted my truck and put a set on. unfortulantly its not a street truck, but i have to break the motor in so I have to drive on my backroads. I'll let you know how they ride in a couple of days.
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I ran them for a while.. I grooved them thou.. They wheren't that bad.. But the welded 14bff made them loud around corners... /forums/images/graemlins/eek.gif
  5. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I am running a set on my DD, they do wander more than a radial tire does, but with good steering components and the right pressure, 25 psi in mine, they are not too bad. They are kind of loud, but not worse than any other mud tread tire. they will vinrate when they are cold, you will swear the truck is going to fall apart, but when they warm up they are fine. My tires took A LOT of weight to balance, but to be expected with a 36" bias ply tire. I like mine, they are not as easy to drive with as the 33" radials I took off, but I can live with it for the extra ground clearance.
    Krennen
    Oh, BTW, I am running a rear Detroit and they do tned to get sguirreley on wet roads and the will chirp real easy if you get on it in a corner. /forums/images/graemlins/thumb.gif
