anyone running hummer locks on a dually front and srw axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fourwheelerjeff, May 12, 2003.
  1. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    if so, do you have some opinions and pics, thanks /forums/images/graemlins/thumb.gif
  2. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    What are you trying to find out?
    /forums/images/graemlins/truck.gif
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    dually front? /forums/images/graemlins/confused.gif
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    No real opinions, but it's something I've heard (and seen in pics) before.
    It works out great for the dually front, the rear, I've only heard of one method that I like, that was the spacers that WOLF359 used. Unbreakable man. There was a guy in TN running the front ones normal and the wheels in the back reversed. Looked a little funny, but he liked it. I don't think I care for that setup exactly, but what ever blows your skirt up...
  5. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I just put mine 12 Bolt Radial Hummer rims and 42's on my dually D60 equipped blazer with C14FF rear. The front works out great the rear end is a little different. I am presently running 2-1/2" spacers on the rear to make the necessary depth for the rim. Havent gone wheeling yet. Nor do I have any pics yet.
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The Dually front axle with a Van width rear would be the ideal setup to run the stock Hummer wheels. </font>
  7. Kyle89K5
    2,273
    OKLAHOMA
    Here's the setup I was referring too.
    These pics came from WOLF359 on his site at www.gohumvee.com
    HTH
    KP
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I still think that that looks dangerous... The paint is wicked cool though, and expertly applied. /forums/images/graemlins/rotfl.gif </font>
  9. Kyle89K5
    2,273
    OKLAHOMA
    After he ran Top Truck with them with no prb's, I'll give him credit. At least he didn't use 6" studs to make it work /forums/images/graemlins/eek.gif It's not a WHOLE lot different than a factory dually hub. Sure it's not cast as one peice, but with the added bracing behind it, it doesnt' look to bad. All this running his 16" /forums/images/graemlins/eek.gif wide hummer rims with 44" boggers. The paint, well, that's a whole 'nother thread right there /forums/images/graemlins/grin.gif
  10. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    Does anyone sell a spacer like that? what does a factory dually hub look like anyway? If wolf makes them, does he sell them as well?
  11. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    As I stated before I am running the Dually D60 front. It has a WMS to WMS measurement of approx. 76-1/2". The standard C14BFF truck rear end has a WMS to WMS measurement of approx. 67-1/4". The C14BFF Van rear end has a WMS to WMS measurement of approx. 70-1/4". The hummer rim has a BS of 7". This is why I have chosen to use the 2-1/2" spacers on each side of the rear axle. I have just purchase a van rearend and will be using it soon, still with the spacers. This will give me an overall WMS to WMS measurement of approx. 75-1/4". I am using spacers from Performance Wheel and Tire in Colorado. Hope this info helps. 42's and Hummer Rims
  12. Kyle89K5
    2,273
    OKLAHOMA
    Not that I've found. Wolf doesn't make them either, at least not the last time I talked to him.
  13. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    That will help, but ideal would be one of the ~ 75" D70HDs out of a Ford.
    If you want to run the rears inside out get the lug ring that came w/ that DRW D60 front so the lugnuts still have an interfearance fit.
  14. nvrenuf
    Jan 7, 2002
    13,078
    246
    Mobile, Al.
    A D70HD out of a Chevy dually pick up would probably be perfect.
    I thought Fords used a regular D70, not an HD. /forums/images/graemlins/confused.gif
  15. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Most of the newer dually pickups use a bolt-on spacer that looks similiar to the one in the pictures, though it is one cast piece (versus welded together). So if done correctly it should be okay.
  16. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    thanks for the replies, i am looking at buying another k30 that is a dually and was thinking of ditching the rear axle and converting to srw, on the low budget poor boy method of running the hummer locks; of course i need another rig like a hole in the head, but that is another thread /forums/images/graemlins/rotfl.gif
