anyone running lifts bigger than 8"?
Discussion in 'The Garage' started by bigoltrux77, Apr 18, 2003.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    anyone running lifts bigger than 8\"?
    what mods do i need for a 10" suspension lift? Driveshaft, u joints etc. I dont know much about the little things. Thanks alot.
  2. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    Re: anyone running lifts bigger than 8\"?
    Why would you want that much lift I like to keep my center ov gravity down low? I might go up to 7 or so but that will be with 3" of body lift
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    longer driveshafts. Steering stuff, crossover best but I guess raise arm, dropped pitman, and drop draglink would get it close. 10" swamprunner kits from Superlift come with steering stuff I know.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The raised steering arm, dropped draglink, longer drive shafts, longer brake lines, parking brake, I think thats about it.
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    your driveshaft angles are going to be misearble. if you have a pickup you could run a divorced tcase, although in a blazer, the divorced case is going to make your rear shaft angle even worse. i would recomend staying at or below a 6" suspension lift if you plan on keeping a stock tranny-tcase combo.
