anyone running long front springs?
Discussion in 'The Garage' started by spoolnaround, Jan 15, 2003.
  1. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Who is running longer springs in the front? How long and what are they out of? how do they work, are you satisfied?
    I am going to order a new front driveline and am thinking of going with a longer spring in the front and move the front axle foreward sn inch or two, any suggestions??
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    if all you wanna do is move the axle get a set od ORD 1" zero rate add a leaves. they can move it up to 1.5", give 1" of lift and have no effect on spring rate at all. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  3. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I'm running rear stock 52" springs up front.I just had to move the front spring hanger forward 2 1/2"(moves the diff 1/2" forward).Make sure you get extended shackles.Other than that they ride soft and flex like mad.Oh don't forget to remove the overload leaf /forums/images/graemlins/blush.gif!The springs give you about 5" of lift.The rear shackles are at about an 45 degree angle,too....perfect for ride and flex.Mike
  4. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    I'd like to see some pics if you've got some.
    Chris
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I've got a custom set of ORD springs up front (45" instead of 44") that locate the axle forward 1"....they're nice and soft and flexy....and they allow the tire to completely destroy all the sheetmetal in the wheel arch area!!! /forums/images/graemlins/blush.gif
    Pics in my gallery...
  6. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    What I am thinking is not only moving the axle foreward but longer springs for more articulation. If you have pics of your front hangers I would dig on seeing them.
  7. BLUESMAN
    Oct 3, 2001
    951
    The front hangers are stock,just air chiseled them off and moved under the body mounts.Gm even has the 4 holes there for you.It nothing fancy.....stock front hangers moved under the body mounts,stock 52" rear springs,ORD shackles.I wanted to move the diff forward 1",but that would of entailed modifing the front hangers.This way it moves it 1/2",but I already had my fenders cut for the 39's,BTW I run no wheelwells.I'll try and get some pics this weekend,I'm way over due to post pics of all the mods!! /forums/images/graemlins/laugh.gif.
  8. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Yeah please post some pics. I talked to you bout this before and I understand what you're talking about with the front body mount already dirlled... pretty cool. Do the shackles hit the frame when the springs compress? With them being at 45* seems like they'd hit. Also can you measure the distance between your axle tube and bump stop bracket, I want to get an idea of how much lift it gave you. Thanks /forums/images/graemlins/thumb.gif
