Anyone running NO steering stabilizer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BurbinOR, May 25, 2001.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Scott at Rockstomper recommended at least at the beginning to try running my rig (D60 front) without a steering stabilizer. So far I can say there is no issue with tracking straight, even with 35" SSR's, but notice a tiny bit of bump steer.
    Anyone try this for long?
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    My rig has the stock damp on it but it has no fluid in it. I dont have any problems with tracking or crazy bumpsteer, but I dont freak out and over react with counter measures when I encounter bump steer either. So.......
    My president is Steve Fox.
    90-350TBI-TCI700-241-33"-10 bolts w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    My K5 doesn't have a steering dampener on it. I think part of the reason I can get away with it, is the large amount of castor that I run. I have extended shackles on the rear of my front springs which increases castor. My Blazer tracks very straight down the freeway and I don't have any noticeable bump steer.
    CB
    1973 K5, 400TPI,TH350, 203/205, Dana60/Detroit/5.38 front and rear, 38" TSL's on steel wheels
    <A target="_blank" HREF=http://www.azk5.coloradok5.com>http://www.azk5.coloradok5.com</A>
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I ran one for a while but after a little rock incident, it drained itself. I'm too damn lazy to take it off. To me, I don't notice anything. Personally, I don't like the idea of something being "dampened" I want the full effect of whats happening down there. I get a better feel for when stuff ain't right.
    Kyle
    89K5
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I recently swapped front axles and havent put mine back on yet.Ive got new ball joints,tie rod ends ,drag link ends,and a new steering box.It drives just fine without them.I think maybe later when things get a little worn in I might have to put them back on.
    All work and no beer makes Frizz a dull boy
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I took mine off when i put on the new tie rod ends, draglink ends and balljoints, and its been fine since then, about 6 months
    90K5
  7. CK5
    May 19, 1999
    21,623
    701
    CO
    I have mine off right now but will be putting it back on. It tracks great down the street but if I hit a bump just right the wheels feel like there going to fall off, I asked Stephen Watson about this and he had a similar situation when he had his off.
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  8. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    My K5 use to get the death shakes when I'd hit the slightest bump also and I tightened up the wheel bearings, rebuilt the driverside king pin and now it's fine. I like the clean look of no dampener.
    CB
  9. CK5
    May 19, 1999
    21,623
    701
    CO
    Yeah, I like the clean look also, that's one of the reasons I don't have it on right now, I will check my bearings, I figured since the axle was rebuilt from Boyce that it would be fine but since I never touched it with my own hands you never no.
    Steve
    Bandwidth FREE ZONE
  10. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I run three. My steering is tight, but everything else on the truck is loose. I ran one until I bought the Swampers. Interestingly enough, I can tell the difference even with the 35's, and like it better this way. As for clean, I could care less. As long as I don't hit'em on the rocks, it's fine by me.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  11. BurbinOR
    5,829
    Oregon
    Well, the entire D60 was rebuilt and is tight as heck. Think I'll go with a single stabilizer just because it will take out that little bit of possible problem - with no real downside.
    Now I need to find one that will clamp around the Rock Rod!
    '79 ONE TON - 406 TPI - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  12. steve85fla
    steve85fla Registered Member
    Mar 27, 2001
    83
    palm beach county FL
    Took mine off after I replaced the steering box, shaft was bent, I run 35"s and no shakes
  13. Cliffy
    Cliffy Registered Member
    Oct 8, 2000
    99
    South Lakewood, CO....... FINALLY!!!
    Another note; I don't think having a steering stabilzer will eliminate or create bumpsteer. I could be wrong but in understanding what causes bump steer I don't see how a steering stabilzer would have any effect on it. I haven't had a steering stabilizer on my truck for over a year and a half and I see no problems.
    Coil sprung 71 blazer.
