Anyone running some squeeze?
Discussion in 'The Garage' started by rjfguitar, Feb 2, 2004.
  1. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Just wondering who is squeezing their motor...how big of a shot? is it a built motor if you are? What's done as far as the rotating assembly? Can a stock crank and rods handle a 50 or 75 shot? I have heard that cast pistons will crack? Can you safely run a smaller shot without cracking cast pistons? Thinking about adding a little bottle to the 406.
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Never thought about adding it to the engine, but used to use a lot of it back in the day for fish bait............
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I may go on the bottle with the buggy. I have hyperuetic pistons so I'm not worried about a 50 shot going through her. Has a forged crank with 4 bolt mains. rods are the only thing to worry about and I doubt they will be a problem, if they are well then I've got a motor to rebuilt. And next time around you better realize it will be a 383 with forged pistons and rods and a little top end work to follow that nitrous, then we will crank out some 100hp shots.
  4. fly_n_hi_yukon
    fly_n_hi_yukon Registered Member
    Jul 8, 2003
    44
    Strange Range, MI
    Cast pistons and stock rotating assembly should be able to handle a 150hp shot easily. I've seen it done before with no problems. The biggest things are to make sure you don't detonate. That is what kills the pistons. Use high grade fuel, back off your timing, and make sure your fuel pump can supply enough fuel to feed the fuel solenoid. Also, never spray at much less than WOT. Good luck, have fun /forums/images/graemlins/thumb.gif
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] WTF? Once again, great tech advise bubba... /forums/images/graemlins/rolleyes.gif
  6. burbanman350
    burbanman350 Newbie
    Feb 3, 2004
    3
    Run MSD if you don't want problems...6AL should work just fine for ya
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] More info please? /forums/images/graemlins/dunno.gif
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Umm an MSD ignition box. I will be running a 6A ignition box, with exterior blaster coil. Better spark help fight detonations.
  9. fly_n_hi_yukon
    Jul 8, 2003
    44
    Strange Range, MI
    Yeah, but whatever rev limiter you use, be sure it cuts spark, and not fuel. Fuel cut under boost/spray = KABOOM
    Do some searching on the MSD site. They have an ignition system that will retard timing under boost/spray. THAT folks, is the cat's ass.
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    hmmmm... /forums/images/graemlins/thinking.gif
  11. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i plan on running a 150 shot if i ever get around to building the 385" stroker for my truck..
    a guy i work with has a 95 z28, lt1 6 spd, and has been running 150 shot on it for over 2 years with no problems and its going on 120000 miles..
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I wan't a little nos but I'm thinking a 50 or 75HP shot. /forums/images/graemlins/dunno.gif /forums/images/graemlins/thinking.gif
