Anyone running this setup?
Discussion in 'The Garage' started by 79Stomper, Apr 6, 2004.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Going to install on my 79 this week and was wondering if you had to do any driveline mods for vibration. Here is what I am going to do. /forums/images/graemlins/whistling.gif
    Rough Country all spring 6" lift w steering arm
    1" ORD Body + body bushings
    Front HD Greasable Shackles
    Extended SS Brake Line Kit
    Rear Zero Rate
    and Hopefully putting on new front and rear bumpers and winch if they show up in time. /forums/images/graemlins/waytogo.gif And then /forums/images/graemlins/hack.gif some sheetmetal.
    Is there anything else I will need to do like drive shafts or maybe drop the t-case?
    /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif
    /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    If you haven't ordered them yet don't order the rear springs and get ORD's shackle flip! You won't rgret ti one bit! If you run those rear 6" lift springs mam o man! /forums/images/graemlins/yikes.gif What a harsh ride! /forums/images/graemlins/yikes.gifJMO!
    Bill
