anyone running Tuff Country shackle flip with the 3" springs?
Discussion in 'The Garage' started by k5-newbie, Feb 3, 2005.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    orderd my lift last week from ORD and found out today that my 2" springs are on back order till sometime next week (no big deal) but I got to thinking about the famous Blazer sag in the rear. I told them to go ahead and send the 3" springs instead of the 2". Hopefully this will lvl the truck or maybe even give it a little rake.
    Anyone have any experience with this or even pics? I ordered the front 6" Tuff Country springs and they should be here tomorrow. I am also doing a D60 and 14 bolt swap when i do the lift.
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It will still sit dead level. The D60 spring perch is 3/4" taller than the 14FF. You need the extra inch in the rear just to adjust for the D60 (I was sitting level with 4" front springs and a shackle flip, then came the D60 front and zero rates in the rear to keep it that way).
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think you'll be real happy with the 3" springs over the 2".
  4. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    noone has any pics?????
  5. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    What they said. I went with 6 inch TC's in front and 2 inch TC's in the rear with the ORD shackle flip. The butt still sagged. I added a 1 inch zero rate from ORD and it still looks like it is sagging. I may be pulling the 2 inch TC's out and ordering a set of 3 inch TC's. I may even go 4 inch TC's and yank the zero rate. I have to measure it as soon as I get it back from the tranny shop.
  6. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    i really didnt want to go 8" in the rear, but I would like to have the option of running zero rates to push the axels out a little. I will see what it looks like when the lift is on
  7. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Check out the thread in Offroad Design's forum about my Blazer having a saggy butt. DP90K5 ended up going with 9 inches total in the rear with 6 inches up front and it put it level.
  8. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Update: got the Blazer back from the tranny shop. It is still sitting 1 inch low. So, I think I'll probably order up some 4 inch springs, remove the zero rates, and measure again. I actually wouldn't mind it sitting a tad bit high in the rear since 99 percent of the time I will be wheeling with a full load of gear in back.
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I had to do the same. I have 7" lift in front and 9" in the rear to level my rig out. Actually, since I installed a 2" block I made (it bolts to the spring pack, NOT a normal lift block) the rear sits approx 3/4" higher than the front. I made some extended shackles for the front that I need to install. That should just about level it out.
